Sticking clutch pedal - '93 C2 - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Sticking clutch pedal - '93 C2
Old 05-25-2004, 09:09 PM
Richard Curtis's Avatar
Richard Curtis
Default Sticking clutch pedal - '93 C2
Noticed this weekend on first long drive since the '93 C2 arrived in No.Va. that the clutch pedal wasn't always fully returning... however, a slight touch to the pedal (with my foot of course) would always cause the pedal to come back up. I've read elsewhere of two possible causes: gummed up shaft on the do-hickey (technical term) down in the pedal assembly (which I've cleaned tonight) AND a need for the clutch slave cylinder to be flushed and refilled (which I'll attempt Friday). Any other thoughts? All help appreciated. Please be gentle, I'm a newbie owner.
Richard Curtis
Old 05-25-2004, 11:50 PM
Not specific to Porsches, but whenever I see this I bleed the clutch system. If it still happens I would check the clutch master for binding.
Old 05-26-2004, 09:58 AM
Rick Lee's Avatar
Rick Lee Rick Lee is offline
Rick Lee has one HoF thread
You should bleed your clutch slave regularly. Once you've had to go through installing a new one, you'll be a believer. I bleed my clutch every single time I bleed brakes. It's an extra 5 min. of work then. If that doesn't solve the problem, you could need a new slave and/or master cyl.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Clutch Help cmartin Porsche Technical Discussions 11 08-24-2004 10:51 PM
To clutch or not cmartin Porsche Technical Discussions 12 06-08-2004 11:10 AM
Clutch replacement help SRISER Porsche Technical Discussions 7 09-22-2003 11:36 AM
Sticking Clutch Question chino Miscellaneous Discussions 5 08-12-2003 10:19 AM
Nice find, my pedal cluster has been rebuilt with brass Gordo Porsche Technical Discussions 2 07-31-2003 12:11 AM
