To clutch or not - Dorkiphus.net
Old 06-06-2004, 01:52 PM
Default To clutch or not
Need a little help. Since the engine it out of the car it only made sense to check the status of the clutch. Prior to the drop I had no clutch issues and generally take pretty good car of the clutch when driving.
After looking at the below pictures, does it make any sense to just replace the disk? I know, replace everything. Thing is my budget is tight and I would rather save a little $$ is possible. The pressure plate and flywheel look overheated to me, but are smooth to the touch. Any advice?
If I do go with a clutch kit, anyone have a recommendation for best price/quality? thepartsbin/Pelican and Vertex are all pretty close in price. Any secrets I'm missing?
Thanks!
Old 06-06-2004, 02:36 PM
markwemple's Avatar
markwemple
I guess it would depend upon the last time everything was replaced. The pp is very strong, so check for craked teeth and hot spots and grooves on it. To check the bearing, turn it slowly for smoothness and noise. I can't tell by your pic but how is the flywheel?
Old 06-06-2004, 04:13 PM
Marc A's Avatar
Marc A Marc A is offline
Marc A
Question in my mind is how much material is left on the disk?? are the rivets close to the edge of the material??
Pilot bearing looks like it could use a good packing with bearing grease.
'05 Mustang GT
'08 E350
'06 LR3
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone
The 958 Conversion
Old 06-06-2004, 05:47 PM
BW911's Avatar
BW911 BW911 is offline
BW911
As long as you're in there .... replace it. You won't regret it.
Bill W.
Old 06-06-2004, 09:11 PM
From the pictures I can see lots of hot spots on pp and flywheel which will only get worse with time and cause more clutch chatter. (Not to mention if the flywheel and pp is flat or not.) Grind flywheel and get new clutch package.
Old 06-06-2004, 10:03 PM
Thanks guys, I needed a reality check. The engine drop wasnt a big deal, but I dont want to do it again any time soon. I'll order a new clutch kit this week.
Old 06-06-2004, 11:15 PM
Next question. Is the aluminum pressure plate worth the extra money? Vertex has it for $399, quite a bit cheaper than most. I think I can get the standard kit for ~$225 w/ some web coupons from another source. Sure, lighter is better, but is it really better in this case?
Any insight is much appreciated!
Old 06-06-2004, 11:34 PM
markwemple's Avatar
markwemple
From what I have heard the sc flywheel is relatively light. BTW mine was only $40 to resurface.
Old 06-07-2004, 12:03 AM
Charlie Stylianos's Avatar
Chris,
Holding the lightweight AL pressure plate and the stock PP in each hand, the weight diffrence is quite noticable. Will you be able to notice this difference on the street/track is another question. My opinion is the butt dyno will probably not notice a difference with the heavier stock flywheel and otherwise stock engine, but a back to back dyno session (if possible) with stock and lightweight flywheel may show an increase of a few HP's. You probably will not notice a faster engine spin up, but with tranny in neutral or clutch disengaged, you'll probably notice the faster wind down.
Pro's: A faster engine spin up due to relieveing the engine a few .lbs of rotating mass means a possible couple more HP's at the rear wheels.
Con's: A faster spin up also means a faster wind down, so good/better heal/toe and revmatching technique required on the track espically if your decel valve is plugged and tranny is on the fritz
BTW: I'd do it just to force myself to be a better rev matcher
Just my $.02
Kyriakos E. Stylianos
Baglama inspired
Old 06-07-2004, 12:07 PM
Rick Lee's Avatar
Rick Lee Rick Lee is offline
Rick Lee has one HoF thread
When in doubt, throw it out. You know, once you have your flywheel cut, you'll need new bolts, should replace flywheel seal, should get a new pilot bearing, etc. I'd go with the light flywheel and/or pressure plate. How many times do you want to do this job?
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Clutch Help cmartin Porsche Technical Discussions 11 08-24-2004 10:51 PM
Sticking clutch pedal - '93 C2 Richard Curtis Porsche Technical Discussions 2 05-26-2004 09:58 AM
Clutch replacement help SRISER Porsche Technical Discussions 7 09-22-2003 11:36 AM
Sticking Clutch Question chino Miscellaneous Discussions 5 08-12-2003 10:19 AM
Clutch Helper Spring Fassi Porsche Technical Discussions 0 04-30-2003 07:50 PM
