http://www.webbnet.com/911/images/99...rack_STEP2.jpg
I line up my input shaft, I look in the alignment hole on the bottom and see that it's off center. I have tried twenty times to get the centering hole centered AND the input shaft marks aligned with no luck. Should I forget about the alignment hole and just make sure the input shaft is aligned per my marks?
Howard 2003 996TT 1993 Mini Cooper (SOLD) 1974 Datsun 260z, 1997 911, 1988 911 |
Line it back up per your marks. The centering hole/pin is for when you put it on the alignment machine. Then you center the indent in the hole, insert the set screw into the hole and then set the toe with the tie rods. It could be that at some point your toe was set without using the centering pin.--Dave
Howard 2003 996TT 1993 Mini Cooper (SOLD) 1974 Datsun 260z, 1997 911, 1988 911 Last edited by 88carrera; 08-04-2013 at 12:08 PM. |
