-   -   Sterring rack centering and steering shaft (https://dorkiphus.net/porsche/showthread.php?t=30737)
88carrera 07-31-2013 02:03 PM
http://www.webbnet.com/911/images/99...rack_STEP2.jpg
I line up my input shaft, I look in the alignment hole on the bottom and see that it's off center. I have tried twenty times to get the centering hole centered AND the input shaft marks aligned with no luck.
Should I forget about the alignment hole and just make sure the input shaft is aligned per my marks?
Porsche tech 08-02-2013 05:52 AM
Line it back up per your marks. The centering hole/pin is for when you put it on the alignment machine. Then you center the indent in the hole, insert the set screw into the hole and then set the toe with the tie rods. It could be that at some point your toe was set without using the centering pin.--Dave
88carrera 08-03-2013 12:53 AM
Thank you Dave! I decided to center the rack using the screw into the divot. I just changed my shocks and ride height and will need an alignment anyway, so I may as well just center the steering wheel.
