Happy Holidays Dorki Style - Dorkiphus.net
Navigation » Dorkiphus.net > Miscellaneous Discussions > Miscellaneous Discussions » Happy Holidays Dorki Style
Old 12-24-2004, 11:42 AM
jpinkert's Avatar
jpinkert jpinkert is offline
jpinkert
Default Happy Holidays Dorki Style
Had some fun in the garage yesterday -- which will continue throughout the weekend.
- Josh
- '72 911T
- '81 SC
Old 12-24-2004, 11:43 AM
Dorki-style usually involves a dozen people and 3 dozen donuts.
Old 12-24-2004, 12:36 PM
And beer.
Old 12-24-2004, 12:40 PM
Mackpipes
That looks way too safe to be Dorki style. Where are the wood blocks? :P
Ted Thomas
2003 325xi
Old 12-24-2004, 12:48 PM
jpinkert's Avatar
jpinkert
Too cheap to buy donuts or beer. And there are wooden blocks if you look carefully -- between the jack stand and the car.
Now if I could only figure out how to get the new trailing arms into the car. Then I'll put the motor back in. The monoballs are just a few mm too wide to fit into the trailing arm mounts.
- Josh
- '72 911T
- '81 SC
Old 12-24-2004, 01:38 PM
Jim Richards
I think any advice will require donuts and beer, Josh. Don't you other guys concur?
Josh, what's the snag you're running into? The new trailing arms should go in the way the old ones came out. Or are they a different size (e.g. 930 trailing arms)?
Old 12-24-2004, 04:43 PM
jpinkert's Avatar
jpinkert
The new trailing arms are carrera aluminum arms. But I've also installed monoballs, which are too wide to fit into the trailing arm brackets. My guess is that the trailing arm brackets have been pinched a little over time due to tightened bolts against rubber bushings. So I made a trip to Home Depot to get enough material to build a small press. It should do the trick...I'm waiting for my little heater to work some magic in the garage.
Wish me luck! Beers are in short supply around here. Only 3...er...2 left.
- Josh
- '72 911T
- '81 SC
Hershey Dorki style OldTee Miscellaneous Discussions 9 04-21-2005 04:59 PM
New User Introduction, questions, Happy Holidays! Paul 951 Miscellaneous Discussions 11 12-16-2004 09:57 AM
Dorki & Family Night- Dec. 5 @ DC Maggiano's 87turbolook911 Fun Runs and Upcoming Events in our area. 41 12-05-2004 04:13 PM
DE in TX.. Dorki Style! (long) jpnovak Track Talk 9 09-21-2004 09:46 PM
Happy Holidays! 87turbolook911 Miscellaneous Discussions 29 12-29-2003 03:20 PM
