Eli, that may help, as would fresh gear lube in the transaxle. OK, here's where I'm not completely certain but will still offer some thoughts...If the problem persists, I'd look at dropping the drivetrain so you can inspect and refurbish the shift fork. It has bushings, bearings and the shaft itself that might be worn. The later Carreras with a G50 tranny had some problems with the shift fork that were solved with an update to the fork assy. Ask RL. It may have been an issue with 964s, too, but I'm not certain about this.
| loud noise coming from front? | michael lang | Porsche Technical Discussions | 1 | 02-27-2005 08:02 AM |
| Time for a citizen's arrest.... | Eli | Miscellaneous Discussions | 4 | 10-01-2004 11:15 PM |
| What time is DE registration? | Trak Ratt | Track Talk | 5 | 01-17-2004 10:02 PM |
| Time To Pass The Torch ... | Doug E | Fun Runs and Upcoming Events in our area. | 1 | 09-30-2003 09:50 AM |
| DE and Time Trials | rs911t | Track Talk | 22 | 08-28-2003 09:47 PM |
