Anyone have a tip for removing the chain covers? Mine has a leak I tried to fix during the drop and apparantly failed. Back to work. I recall it was a PITA to remove because of the o-ring holding on tight. I think it's warped and I don't want to warp it anymore prying from the edges.
Anyone have a good tip?
Grab the lip that the engine sheetmetal bolts to with a stout pair of vise grips (pad the jaws with duct tape) and pull.
Did you change the gaskets when you had the engine out? If not, they will be stuck on there and you will probably need a razor blade to get all the stuff off. Be careful when retorquing these and don't death grip it.
Yeah, I changed them when the engine was out. It's leaking enough now that it couldn't possibly be fusing on there
Steve,
Make sure all gasket material is removed from both the chain box and the cover before reinstalling. Also, you can check for warping by smearing some oil around the gasket surface and placing it on a sheet of wax paper over a flat surface (like a counter top). Remove cover from wax paper, then you shold be able to see high/low spots if any.
| 3.6 Chain tensioner inspection | cmartin | Porsche Technical Discussions | 0 | 04-16-2005 07:39 PM |
| PLEASE HELP ... NEED CAMSHAFT REMOVAL TOOLS | Doug E | Tools Needed/For Loan | 3 | 12-02-2003 11:01 PM |
