Mr. Clean AutoDry (& clutch cable replacement) - Dorkiphus.net
Navigation » Dorkiphus.net > Miscellaneous Discussions > Miscellaneous Discussions » Mr. Clean AutoDry (& clutch cable replacement)
Old 09-06-2004, 09:16 PM
Lucky's Avatar
Lucky Lucky is offline
nothing here, move along
Default Mr. Clean AutoDry (& clutch cable replacement)
I was at Target today and saw dozens of this contraption on display by the automotive section (well they call it "automotive" but it is mostly filled with neon cup holders, hands-free kits for cell phones, and other got-to-haves).
Being the conspicuous consumer that I am, I decided to give it a try...
Surprise, surprise. It works. It's a real time saver, too, since it eliminates the need for a bucket of soapy water in addition to a spot-free finish without the need to wipe the car down with a chamois. The key to the spot free finish is careful and thorough rinsing (in the filtered mode) -- which takes 4 or 5 minutes for a 911. Big SUVs would take a bit longer to rinse properly.
Downsides... in addition to the time-consuming rinse, you have to use special "Mr. Clean AutoDry" soap and filters, which means each wash costs about $2 in supplies. Given that I only wash the 911 about once a month and the daily drivers go through the automated car wash, this isn't much of a cost.
BTW, I spent most of today doing track-prep maintenance -- new brake pads, brake fluid flush/bleed, and replacement of a worn clutch cable. The clutch cable was really easy, but I did encounter one puzzler when I fed the new cable in all the way and still couldn't find the end up by the pedal cluster. I pulled it out and re-fed it, being careful to aim it towards the driver's side of the tunnel... that did the trick. All else was simple. What a great car to work on!
-- John
'20 RAM 1500 Laramie
'19 X3
'16 Camaro RS
'00 Boxster S
'86 Carrera Coupe
'85 Jaguar XJS v12
'88 Integra RS
'74 Toyota Celica GT
'69 Camaro
Old 09-06-2004, 09:33 PM
Doug E's Avatar
Doug E Doug E is offline
Doug E
So are we going to see you on one of the infomercials endorsing this product Mr. Brady ?
Congrats on the clutch cable install ... after doing mine I couldn't believe I put it off for as long as I did.
BTW, what's the next track event for #86?
1981 911 SC
Old 09-06-2004, 10:08 PM
Lucky's Avatar
Just a happy customer. But for the right $$$$ I'd do anything!
I've had the new clutch cable sitting in my garage for over a year! I'm usually not that bad of a procrastinator, but I was dreading this job as every other car I've replaced clutch cables on has been a PITA. This was a breeze.
Next scheduled track event is NASA @ SP on the 18th/19th. After that is Zone 2 (10/1 @ SP) and Potomac (10/2-3 @ SP) (if I ever get off the dreaded Potomac waitlist!).
Doug (et al), have a blast at VIR! Wish I could join you guys, but my next trip to VIR will have to be in the Spring.
-- John
'19 X3
'16 Camaro RS
'00 Boxster S
'86 Carrera Coupe
'85 Jaguar XJS v12
'88 Integra RS
'69 Camaro
Old 09-06-2004, 10:24 PM
Doug E's Avatar
Doug E
VIR is not in the cards for me this year either as SP 10/2 & 10/3 are my next track days.
Have fun with NASA and hope the Potomac waitlist works out for you.
1981 911 SC
Anyone Replace a clutch cable? William Miller Porsche Technical Discussions 6 03-01-2005 10:40 PM
Clutch Help cmartin Porsche Technical Discussions 11 08-24-2004 10:51 PM
Clutch replacement help SRISER Porsche Technical Discussions 7 09-22-2003 11:36 AM
