Plug Wire Question - Dorkiphus.net
Old 05-12-2004, 09:55 AM
Default Plug Wire Question
I know that some of you use different than factory wires in your cars. I have been told that I should replace my plug wires, because as someone said on PPBBS "they were likely installed in a place called Stuttgart." What plug wires did you select and why? I am now running an MSD, and that calls for "non-solid core" wires. I would like to go stock if I could still use them (with current set up), but they are super expensive from PP. ~185 for one side: 3 plugs! Vertex supposely has OEM sets for $185, but I can't tell if that's for all 6.
Also, it appears that the factory wires are the only ones that need to be grounded. I assume it's b/c they have the braiding. Can someone explain this to me?
Many thanks!
Newbie Question Regarding Bleeding Brakes TD in DC Porsche Technical Discussions 21 05-26-2005 07:54 AM
First spark plug change this evening, do I have it right? 4to8m8 Porsche Technical Discussions 7 12-17-2004 08:17 PM
SC Radio and alarm renovation William Miller Porsche Technical Discussions 7 08-31-2004 12:59 PM
SC oxygen sensor wire question GB83SC Porsche Technical Discussions 8 08-27-2004 02:28 AM
Potomac Question HPDC Question Doug E Track Talk 43 09-30-2003 07:36 PM
