Finally getting to this. Over the weekend I started with the disassembly.
Disassembly begins. ![]() I warmed up the engine before I put the car on the lift, and drained the oil. ![]() Started at the front. ![]() ![]() ![]() ![]() A lot of that ugly black stuff around the strut mounting. ![]() ![]() I tried to clean up a bit of the mess. ![]() Here is the rest of the front suspension. ![]() All this need to be cleaned up. ![]() Removing the original inner pieces from the struts. ![]() Got most of the removed item cleaned up a bit. ![]() A few more parts to clean. ![]() The small stuff I will zinc plate, and the larger items powder coat. To be continued. Cheers Engelbert
Awww yeah! Can't wait to follow this one...
Excellent, thanks for posting.
I really like your cleaning process, so much nicer to work with clean parts.
90% of any older car project is cleaning.
...that's why we all drooled over your hot-parts-washer and ultrasonic cleaners VG!!
Engelbert, What do you use to clean your parts?
'64 356 SC '73 914 2.0 (2.8/6 conversion in progress) '65 Ducati Falcon 80 '67 Ducati Cadet 100 4-speed ‘19 SQ5 Gone but not forgotten: '02 S6 Avant - trans blew, but rebuilt as a 6-speed by new owner '99.5 A4 2.8QT - tree fell on it after 20 years ‘74 MB 280C - traded for paint/rust repair/6-conversion mods on the 914 |
It depends. The lose dirt I usually just scrap off, wash oily stuff off with oil eater. Brake dust with Brake cleaner. Once oil and dirt is off, beat blasting before coating, plating, etc. I also have oil eater in my parts washer.
Continue with the rear suspension disassembly.
![]() In order to remove the T-bars, the side skirt has to come off, which is a good opportunity to clean. ![]() The T-bars came out without a fight. ![]() And the inside of the tube looks clean and no rust. ![]() Now getting the old rubber off is a PITA. One down, one more to go. ![]() Rear suspension hardware after removal. ![]() Got most of it cleaned up a bit. ![]() Back to the front. The hubs are clean. I think I just give them a clear coat of paint. ![]() Got the hardware for the front ready. Just did clear Zinc, no yellow. ![]() Got the cross member and dust shields coated. ![]() Started to clean the wheel wells and the areas where I cannot get later when the suspension is back installed. ![]() ![]() More to come. Cheers Engelbert
You may have mentioned this before but what are you doing to clean the wheel wells and under the tub? Looks great and I will want to do that to my project.
looks great as always...what is oil eater?
I use a spray bottle filled with oil eater 1/2 and 1/2 water, a kitchen brush, rags. Messy work.
