Ted's rebuild update - Dorkiphus.net
Old 01-13-2004, 11:18 PM
Mackpipes
Default Ted's rebuild update
Well it's all the way down to the case. Tomorrw I pull the head studs. I only had one snag durring the teardown. I rounded off the inside of two of the head stud barrel nuts. No biggie, they came right out with a Snap-on easy-out bit.
I found there was serious blow-by on the #4 head as well as the #6 head, #4 being the worst of the two. I also found a broken top ring on the #4 piston. The #4 head only looks off color with some carbon buildup on the outside of the sealing surface, no pitting or charing. I'm hoping it can be machined so I can keep it. Otherwise I'll go 3.4. Tear down was fairly straight forward. Now comes the painstaking wait for the machine shop.Thank again to all who lent a hand. I'll post pictures in the morning.
Ted
Ted Thomas
2003 325xi
Old 01-14-2004, 07:54 AM
Jim Richards
No extra HP for you Ted. You're already a menace! :P
Old 01-14-2004, 08:32 AM
Just tell us when it goes back in, I'd like to show up this time. I need some closure!!
Old 01-14-2004, 02:40 PM
William Miller's Avatar
William Miller
Might as well do the bottom end. If everything is in good shape it wouldn't hurt just to put in some fresh bearings and seals. That's only $200-$300 from this point and really not much more work. It will give you something to do while your waiting for the machine work.
Better measure your piston ring groves. Any ideas on what caused the ring to break? Mine was #4 to ring as well. I bet that is the majority of the reason for the bad leakdown and the cylinder head leak was not that bad. Did #6 show low numbers on the leakdown.
Check out the Alusil thread on Pelican. I just got some new info from KS about their cylinders and prepairing them for re-ringing. In fact one guy is offering to do it for free as a test case. You can't beat having it done for NADDA Zip nothing.
Thanks! WCM (Bill)
'81 911 SC Red Targa 3.6
'08 335i Blue Sedan
'05 Chevy Tahoe green
'98 Jeep Cherokee XJ "Blue"
'01 Toyota 4 Runner "Pearl"
Darnestown, Maryland
Old 01-14-2004, 06:12 PM
Mackpipes
Default update update
Preliminary inspection reveals all mating surfaces are good enough to keep what I've got. The heads will be fly cut and the cylinders honed. I am going with a hotter cam as well as stiffer valve springs.
Bill,
I'm not going to split the case because I don't have any leaks and the motor has only 75K on it. I think the ring broke because of the heat from the extra o2 cause by the leak ( just a guess). I will be doing rod bearings as well as upgraded rod bolts. The heads and cylinders are at the machine shop as of this afternoon. I'm pulling the head studs and doing some clean-up on the case tonight.
I might just have this thing up and running in lesss than a month.
Ted
Ted Thomas
2003 325xi
Old 01-14-2004, 07:02 PM
Charlie Stylianos's Avatar
Ted,
Thats great news!!
So the heads were damaged from slapping against the C's and can be repaired, good news. How is the 'sealing ring' on the cylinder tops repaired, or were they not damaged?
Were the heads visibly damaged, or was some type of precise measuring tool needed? How about the cylinder tops.
I'm 3.2 challenged and just curious.......
Kyriakos E. Stylianos
Baglama inspired
Old 01-14-2004, 08:04 PM
Marc A's Avatar
Marc A Marc A is offline
Marc A
What machine shop are you using??? Inquiring minds want to know.
Great luck on the Heads and P&Cs.
'05 Mustang GT
'08 E350
'06 LR3
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone
The 958 Conversion
Old 01-14-2004, 08:53 PM
SRISER's Avatar
SRISER SRISER is offline
SRISER
What a stud...
Sam
'02 996TT
'07 Audi S4 Avant (yeah its a wagon, so?)
Past:
'06 C55 AMG
'03 Discovery
'06 C350
'91 Camaro RS (Don't ask)
'88 911 (sniff...tear...)
'01 BMW 330i
'01 BMW X5
'92 MB 300E
'02 Audi A4
'89 BMW 635 CSi
'84 944
'93 Mazda MX-6
'91 Z28
'84 318i
Old 01-14-2004, 09:18 PM
Mackpipes
Default Check the Gallery
Just loaded a whole mess-o-pictures to the gallery. Enjoy!
Ted Thomas
2003 325xi
Old 01-14-2004, 10:36 PM
Nice pics Ted. Especially like the "bluing" of the #4 jug on the left edge. Should be perty pretty when you get them back.
Good job.
Lucas Caliper rebuild kit? Charlie Stylianos Porsche Technical Discussions 10 04-06-2005 05:52 PM
Rebuild Update APKhaos Porsche Technical Discussions 22 02-22-2005 08:27 PM
Rebuild Project Update: Almost There !!!! Doug E Porsche Technical Discussions 12 01-31-2004 11:41 AM
rebuild, replace? Mackpipes Porsche Technical Discussions 22 10-16-2003 09:08 PM
915 Rebuild Jazzbass Porsche Technical Discussions 4 02-27-2003 02:56 PM
