rebuild, replace? - Dorkiphus.net
Old 10-14-2003, 02:06 PM
Mackpipes
Default rebuild, replace?
This past weekend's DE was an absolute blast! Learned alot, and took the advice of APKhaos to start breaking like a man. Well, if breaking like a man entails boiling my break fluid and frying the seals in my rear calipers, mission accomplished.
On my way home from the track I noticed the car dragging a bit. It turns out my left rear caliper is dragging a piston. On the advise of a local shop, (to remain unnamed) replacing the rear calipers was the sound thing to do, rather than rebuild. The owner did say he would rebuild them but couldn't garantee the integrity or performance of the calipers. His reasoning was the caliper was no longer true.
I rebuilt my front calipers a year ago for the same reasons and have had no trouble with them at all. My question is this: Should I rebuild or replace my rear calipers?
I think he suggested replacement because of the liability of workmanship. If the rears failed again it would be the fault of the caliper not the rebuilder.
Thanks,
Ted
Ted Thomas
2003 325xi
Old 10-14-2003, 02:21 PM
APKhaos's Avatar
APKhaos APKhaos is offline
APKhaos
There are a few situations where replacement of the caliper is indicated, including failed seals between the caliper halves, corrosion [especially in the piston bores], etc. Caliper no longer 'true'? Sounds a little sketchy to my ears - what dimension is purportedly out-of-true, and how was this measured??
If the caliper is sound, then a rebuild is simple and effective. Check the state of the piston, and replace if it is corroded.
Oh, and get a cool brake kit on those front brakes, Ted. Now that you are runninf in Blue, and beginning to 'brake like a man', the heat will become an issue. Congrats on your rapid progress on the track
Tony K
PCA Potomac, Rennlist Member
89 944 Turbo
85 Carrera - Sold
TrackVision
944Cup
Old 10-14-2003, 02:25 PM
Marc A's Avatar
Marc A Marc A is offline
Marc A
Blue . . . . . Oh s*&% we're never going to hear the end of this.
PS: Rebuild the suckers, rears don't take the heat that the fronts do, heed Tony's warning about the piston condition.
'05 Mustang GT
'08 E350
'06 LR3
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone
The 958 Conversion
Old 10-14-2003, 05:34 PM
Rick Lee's Avatar
Rick Lee Rick Lee is offline
Rick Lee has one HoF thread
Ted, you're not gonna get anywhere until you pull your engine. Then we can figure the problem out. Of course, I'd recommend (at the very least) an upgrade to Boxter calipers.
2023 BMW S1000R
2022 BMW 530i
2021 MB GLA250
Old 10-14-2003, 06:46 PM
Dan M's Avatar
Dan M Dan M is offline
Dan M
Since it is much easier to replace than rebuild, that is the direction most shops will go. And yes, if I owned a shop, I would probably replace too for liability and profitability reasons.
Personally I would rebuild it myself and save your money for other things. Seems odd that it would no longer be "true", whatever that means. I had to replace one caliper due to corrosion and I bought a used one from a junk yard and rebuilt it.
--Dan
Old 10-14-2003, 06:53 PM
FWIW
The only Porsche calipers that I know whose flex warps rotors or create pad wear issues are the early S alloy calipers. They were great for light weight (less unsprung weight) and increased size but would flex under heavy use.
Even these don't get tossed, just get rebuilt (if overheated the seals) and cool brake kits added.
Two years ago at VIR this happened to us at an HSR race. New rotors, pads and more brake hose cooling solved the problem.
Old 10-14-2003, 10:19 PM
BW911's Avatar
BW911 BW911 is offline
BW911
Gee Ted, I think you should replace with Big Reds all around, get rid of those wheels for some 17s, and maybe drop the engine while you are at it.
- Bill W.
Old 10-15-2003, 05:03 PM
Mackpipes
Default House poor
I just picked up two rebuild kits from ASG. I guess I'll have to see what condition the pistons and inside of the calipers look like. If they are not rebuildable I will upgrade. First order of business is a brake cooling duct kit.
Hey Bill, got a touch of the Leschanderitis? On that note, Performance products is selling 8 piston calipers with 15" rotors. I wonder if I can get those in ceramic?
Thanks for all the input,
Ted
Ted Thomas
2003 325xi
Old 10-15-2003, 05:12 PM
BW911's Avatar
BW911
Default Leshanderitis ....
Naw Ted, we just want to see you work and spend. You're picking up this track driving so fast we need to do something to slow you down.
Bill
Old 10-15-2003, 09:59 PM
Ted is in blue after his 2nd DE? Is that right? Through green is less than one month? Wheeeww.... now I can start my DE career next year in green with nothing to worry about .
Ted - let me know if want some help rebuilding the calipers - I just did all four on my car and built a few tools to make the job easier.
Brake caliper rebuild kimlangley7 Porsche Technical Discussions 3 05-03-2005 03:47 PM
Lucas Caliper rebuild kit? Charlie Stylianos Porsche Technical Discussions 10 04-06-2005 05:52 PM
SC Suspension Rebuild Parenn911 Porsche Technical Discussions 13 02-21-2005 04:25 PM
Rebuild Project Update: Almost There !!!! Doug E Porsche Technical Discussions 12 01-31-2004 11:41 AM
915 Rebuild Jazzbass Porsche Technical Discussions 4 02-27-2003 02:56 PM
