Old gasoline - ok to mix for DD? - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Other Technical Discussions » Old gasoline - ok to mix for DD?
Old 04-16-2015, 06:17 PM
flipb's Avatar
flipb flipb is offline
flipb
Default Old gasoline - ok to mix for DD?
I've got about a gallon of gas leftover from an old lawnmower. If I had to guess, it's at least two years old, but doesn't smell "off" to my untrained snout. I'm sure it's e10, nothing else has been available around here for years.
I can dispose of it (free) in a Fairfax County waste facility. But I'm wondering if I should just add it to the tank of my DD, a 4-cylinder Kia. The tank holds about 16 gallons, I'd imagine the one gallon of old gas probably wouldn't make much difference as it would mix with the fresh gas in the tank.
Use it or dump it?
2013 Model S 60
Old 04-16-2015, 09:04 PM
I would use it in the mower before I put it in my car. Clogged filter, injector... if there are any issues.
Old 04-16-2015, 11:33 PM
bsurdam91 bsurdam91 is offline
bsurdam91
Ask yourself if a $3 gallon of gas is worth taking a chance
Brad
2005 911 S (Track)
2012 911 Cab Black Edition (Garage Queen)
2017 Ford Expedition (Tow Vehicle/Hauler)
2015 Cayman (DD)
2015 Boxster (Wife's Toy)
1987 911
2000 Malibu Flightcraft (Barefoot Boat)
Old 04-16-2015, 11:59 PM
1 gallon of gas... mixed in with 15 'new' gallions. Kia. Dump it in and just drive.
Old 04-17-2015, 04:12 AM
Kia. Dump it and just walk
Fixed it for you
Lucky owner of a couple 911s
1965 Honda Sport 50
Old 04-17-2015, 07:40 AM
IMHO, I'd recommend running the old gallon through a coffee filter first. And then mix it with some newer gas for use in your current lawn mower. After filtering, it's probably OK to run through a Kia, but AFAIK, fuel injections systems can be a bit more finnicky than a lawnmower's carb.
Old 04-17-2015, 07:53 AM
Dandelion's Avatar
Dandelion
1 gallon of gas... mixed in with 15 'new' gallions. Kia. Dump it in and light the match.
Originally Posted by Patrick3000 View Post
Fixed it for you
...and fixed again.
2016 GT4
2012 Cayman R
2005 Lotus Elise
1994 RX-7 R2
Old 04-17-2015, 08:01 AM
No water, no chunks, no problem.
Old 04-17-2015, 09:43 AM
flipb's Avatar
flipb
Pretty good variety of answers... I'm not worried about the cost of wasting the gas, I'm more debating whether I need to make the trip out to the Fairfax County waste disposal facility vs. just "dispose" of it by using it.
I just drained the lawnmower tank... it hasn't run in 2 years and I want to make sure I give it the best chance of firing up and not getting fouled. Oil looks good, air filter and spark plug look fine and engine turns freely.
The Kia has been a reliable, practical beast... albeit a soulless one. That's why I have the 914.
2013 Model S 60
Old 04-17-2015, 09:57 AM
Make sure there are no chunks, mix a little fuel stabilizer in it, dilute in the Kia and go. You've probably put worse gas in your car straight from the pump.
