Purchased this 944 from jhimsey a few months ago and for the most part
I'm very satisified (although I wish I would have kept the 911). It runs great and everything works but I have few items that needs to be addressed. 1. I get a 'clunk' when I let the cluth out normally. If I let it out slow, no clunk. Sound appears to be coming from under the gear shift. I guess it could be either the clutch or differential (ya think?) It make the 'clunk' whether motor is running or not, in gear or neutral. Is there any way to isolate the source? 2. Exhaust sounds like shi* going through a tin horn. Any way to improve it to a more (shall I say) masculine sound? Thanks.. |
First you have to move the transmission closer to the engine. Actually you should put it right behind it that way the linkage won't 'thunk.' For the exhaust you need to add 2 cylinders and put the engine in the back of the car to get the full resonance. If you do that all your problems will clear up
Hunt 611racing.com OG Racing Team Vimeo https://www.youtube.com/user/Streak986 1999 SPB #611 2004 Wrangler “That’s how people like you work. Your ego is so out of whack that it will do what ever it can to protect itself. And people with a messed up ego can do these mental gymnastics to convince themselves they’re awesome when really they are just douche bags” - Kyle, South Park "If you need to focus maybe you should buy the book and take it home" - MLIN |
the clunk sounds like maybe a failing rubber center clutch disc. If it's the original clutch I'd bank on it. A modern replacement should have a conventional spring hub.
nate
-- '88 944 NA '55 Studebaker Commander coupe (resto-rod) ugly Ford truck |
Greg Rockville MD |
Ethan Cooper Bowie, Maryland 1987 Porsche 944 LT1 Swap, disassembled for paint/body 1986 Porsche 951 5.3 L33 (LS) swap, Ground Control Koni Coilovers. Rear ended and totalled 1986 Porsche 951 332ci LS Turbo Swap in progress 3x 1987 Porsche 924S; 1989 Porsche 944 2.7 NA; 1987 Porsche 944 NA |
Congrats, you need a new spring centered clutch, and all the goodies and labor that accompany it.
Don't drive it around with this clunk, it's not so good for the transmission. What you are hearing is the metal safety catch tabs spinning on the clutch, and then catching. The rubber center has detached. The good news is that once you put the new clutch in, you probably won't ever need another, and your car will be a whole lot more fun.
Mike C. 1987 944S 2005 Mini Cooper S |
