'84 944 Questions - Dorkiphus.net
Old 05-31-2008, 08:13 PM
Bill P Bill P is offline
Bill P
Default '84 944 Questions
Purchased this 944 from jhimsey a few months ago and for the most part
I'm very satisified (although I wish I would have kept the 911). It runs great and everything works but I have few items that needs to be addressed. 1. I get a 'clunk' when I let the cluth out normally. If I let it out slow, no clunk. Sound appears to
be coming from under the gear shift. I guess it could be either the clutch or differential (ya think?) It make the 'clunk' whether motor is running or not, in gear or neutral. Is there any way to isolate the source? 2. Exhaust sounds like shi* going through a tin horn. Any way to improve it to a more (shall I say) masculine sound? Thanks..
Old 05-31-2008, 10:59 PM
SilverStreak's Avatar
SilverStreak
This is an easy fix.
First you have to move the transmission closer to the engine. Actually you should put it right behind it that way the linkage won't 'thunk.'
For the exhaust you need to add 2 cylinders and put the engine in the back of the car to get the full resonance.
If you do that all your problems will clear up
Hunt
611racing.com
OG Racing Team
Vimeo
1999 SPB #611
2004 Wrangler
Old 05-31-2008, 11:21 PM
Old 05-31-2008, 11:45 PM
N8N N8N is offline
N8N
the clunk sounds like maybe a failing rubber center clutch disc. If it's the original clutch I'd bank on it. A modern replacement should have a conventional spring hub.
nate
'88 944 NA
'55 Studebaker Commander coupe (resto-rod)
ugly Ford truck
Old 06-01-2008, 08:56 AM
Potomac-Greg's Avatar
Potomac-Greg
Well, it will clear up some problems, and create many others.
Greg
Rockville MD
Old 06-24-2008, 03:40 PM
coop's944inMD's Avatar
coop's944inMD coop's944inMD is offline
coop's944inMD
This will only appeal to you if you like Volkswagen Beetles and driving backwards around corners...
Ethan Cooper
Bowie, Maryland
1987 Porsche 944 LT1 Swap, disassembled for paint/body
1986 Porsche 951 5.3 L33 (LS) swap, Ground Control Koni Coilovers. Rear ended and totalled
1986 Porsche 951 332ci LS Turbo Swap in progress
3x 1987 Porsche 924S; 1989 Porsche 944 2.7 NA; 1987 Porsche 944 NA
Old 06-25-2008, 09:08 AM
rmconner80 rmconner80 is offline
rmconner80
Congrats, you need a new spring centered clutch, and all the goodies and labor that accompany it.
Don't drive it around with this clunk, it's not so good for the transmission. What you are hearing is the metal safety catch tabs spinning on the clutch, and then catching. The rubber center has detached.
The good news is that once you put the new clutch in, you probably won't ever need another, and your car will be a whole lot more fun.
Mike C.
1987 944S
2005 Mini Cooper S
