Roll Cage Advice - Page 2 - Dorkiphus.net
Navigation » Dorkiphus.net > Miscellaneous Discussions > Miscellaneous Discussions » Roll Cage Advice
Old 02-16-2005, 09:57 AM
Rick Lee's Avatar
Rick Lee Rick Lee is offline
Rick Lee has one HoF thread
I'm taking a hard look at the Tweeks roll bar, not cage. Any ideer on how bad the install is on these?
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 02-16-2005, 10:17 AM
I have a safetly devices cage in my red car. I was surprised how much room I still had to in the car when I packed up for DE last weekend. I tote around a plastic storage box on the back shelf and it fit just as easily as it did pre-cage. I will say that with fixed seats it would be a bear, not sure anything solid would fit.
Old 02-17-2005, 08:51 AM
CrewChief's Avatar
Freeloader
CrewChief
Matthew,
I'm just curious. Why do you want a cage?
Old 02-21-2005, 09:37 AM
Chopper Dropper's Avatar
Chopper Dropper
Concur with John here. What run group are you in first. How much, if any, are you going to run your car on the street, Hours spent in the car % wise? A cage will be at least annoying on the street, more likely dangerous in a fender bender when you bounce your noggin off the cage or roll bar even if you think its far enough away to be of no concern and covered with foam. If you have a track car that you run once in a while to go get gas, run for a pretech inspection, take your chances. Remember a hard roll over in a 911 is not likely to cave the roof in to seat level, and as long as you are not held upright you will get pushed down. Yeah I know there are exceptions, but bump your noggin against a roll bar at 20 MPH and you will probably say more than ouch. Sure I know it looks cool.
Dirk
Bike Advice cmartin Miscellaneous Discussions 33 08-21-2006 09:36 PM
Roll Cages and Inspections TD in DC Miscellaneous Discussions 9 06-01-2005 11:19 AM
roll cage recommendations for targa? Spike Track Talk 5 05-24-2004 08:28 AM
Seeking advice - garage lift Jim Richards Miscellaneous Discussions 11 01-28-2004 12:56 PM
3.0 into 911E advice needed for local porsche nut chuckw911e Porsche Technical Discussions 42 10-15-2003 05:12 PM
