924S Head Work - Dorkiphus.net
Old 10-29-2024, 09:21 PM
P-Fast P-Fast is offline
P-Fast
Default 924S Head Work
Hi all,
I was recently gifted an ‘88 924S that hasn’t been driven in a good 8 years. After replacing most of the ignition system (plugs, wires, distributor cap, battery), I got it running, but it spews lots of oil smoke from the exhaust and runs terribly. Compression test results seem pretty good best I can tell (167, 175, 170, 160) and leak down test was all at 9% or better even when tested completely cold. Heard some blow by through the intake in cylinder 3.
With this, I’m suspecting my valve seals as the source of the oil in the combustion chamber. Does that stand to reason? If that is indeed the culprit, do you all recommend a valve seal replacement with the head still in the engine bay? Or should I do a full head rebuild just to be safe? Any suggestions how to further determine whether a valve seal replacement is likely to solve my smoke issue?
Thanks!
Jeff
Garage:
2015 Competizione Rosso Alfa Romeo 4C Coupe (track-prepared)
1993 Vintage Red R-Spec RX7 FD (heavily modded)
2016 Cayenne Turbo
1987 Porsche 924S
Cars in Heaven:
1996 Opel Frost Mustang GT (heavily modded)
Sold Vehicles:
2012 Cayenne S
2007 Cobalt Blue Cayman S (suspension mods)
2004 Suzuki Blue SV650S (bone stock)
Old 10-29-2024, 10:25 PM
TurboPooch's Avatar
Now known as Robbie's dad
TurboPooch
With those compression numbers and leakdown a bit out of range and with air noise past valves, it's time for a head rebuild. Last one I had done was only about $300 for just the head work. I'm sure its more expensive now. I did the disassembly and reassembly myself. If it smokes all the time it may be time for rings as well as valve seals typically only cause smoke at startup. But since this thing sat for so long it may be a case of the seals stuck to the stem and have dislodged allowing oil to get past the guides. Good luck...
89 944 Turbo Race car
98 993 C2S w/Aerokit II
70 Boss 302
86 Mustang SVO
24 F250 SD Godzilla
Old 10-29-2024, 11:00 PM
I've done a few different cars over the years. Worth the effort to me unless you have bad compression or clearly a head gasket or other issues you want to address.
Old 10-30-2024, 12:58 PM
P-Fast
Thanks for the advice! What shop did you use/would you recommend in the area? I’m in Alexandria.
Jeff
Garage:
2016 Cayenne Turbo
1987 Porsche 924S
Cars in Heaven:
Sold Vehicles:
2012 Cayenne S
Old 10-30-2024, 09:12 PM
edevinney's Avatar
Most Courteous Driver
edevinney
I had a VW VR6 head rebuilt by Tysons Machine, seems like fine work and they do stuff for Chapman. Farther out I had a Volvo redblock head done by Billy at Performance Machine in WV. Also fine work, more performance oriented if that's desires.
Old 10-30-2024, 10:42 PM
P-Fast
Thanks! Hadn't heard of either of these companies before - I'll check them out.
Jeff
Garage:
2016 Cayenne Turbo
1987 Porsche 924S
Cars in Heaven:
Sold Vehicles:
2012 Cayenne S
Old 10-30-2024, 11:40 PM
I assume Ed meant Billy Ring at Performance Autoworks (8063 Leetown Rd, Middleway, WV 25430 -- (304) 728-8222). Billy is a master, especially with air-cooled--he learned at the knee of Dave Coleman.
Is Allied still in business? They're in Falls Church. I last used them in 1978 so can't vouch for their current work...
Old 10-31-2024, 11:40 AM
P-Fast
Thanks Dr K!
Jeff
Garage:
2016 Cayenne Turbo
1987 Porsche 924S
Cars in Heaven:
Sold Vehicles:
2012 Cayenne S
Old 10-31-2024, 12:09 PM
Casey914's Avatar
Casey914 Casey914 is offline
Casey914 has two HoF threadsCasey914 has two HoF threads
Burtonsville machine shop did my 968, a 944 turbo and 2.2L heads.
Old 10-31-2024, 03:22 PM
jhsmith's Avatar
jhsmith jhsmith is offline
jhsmith
Billy Ring at Performance Auto Works in Kearneyville WV
Jim
"2014 & 2017 Central PA SCCA Witch's Rallye - Best Team Costume Award"
White/Green '91 SSM Miata #01
Silver '00 Miata
Green '96 911 (993) Carrera #409
Blue '09 911 (997.2) Carrera S Cab
Black '15 Yukon XL w/ '98 Trailex (Tow Vehicle)
Burnt Orange '75 FJ40
Yellow '19 718 Boxster (wife regretfully sold it to fit the grandkids)
Black '83 911SC Targa (regrettably sold when the second car seat didn't fit and 2nd daughter came along)
