Sportomatic service? - Dorkiphus.net
Old 09-24-2024, 07:39 PM
Jonathan Jonathan is offline
Jonathan
Default Sportomatic service?
Anyone know a mechanic who could take a look at a sportomatic transmission? The gears are grinding, and while I suspect it is an electrical connection problem with the electronic clutch I might need more mechanical expertise. Also - anyone know who can repair a driver side door latch? Thanks.
Old 09-24-2024, 08:23 PM
For old transmissions, ASG, maybe? Geoff and Ray have worked on a lot of older Porsches. And maybe try Roger Bratter at AutoTherapy (he's probably the closest to you, as he's by G'Burg Airport).
Old 09-24-2024, 08:44 PM
Jonathan
Cool thanks.
Old 09-25-2024, 07:59 PM
Who did your transmission work (clutch) and how long did it take to finish
Lucky owner of a couple 911s
1965 Honda Sport 50
Old 09-25-2024, 08:22 PM
It’s been awhile and I have limited experience, but like the VW version most issues are usually with the switches in the shifter.
Old 09-25-2024, 09:10 PM
Switched ground, hopefully its just a dirty contact. Simple enough to check for vacuum or leak. Found this from an old pelican bookmark.
https://forums.pelicanparts.com/pors...rol-valve.html
Old 09-26-2024, 12:21 AM
Also Matt de Maria, who is now also at the air park. Although he is no longer in his solo shop I believe his number is still listed as Stuttgart Performance Engineering. And Roger Bratter is right near there, too.
Old 09-27-2024, 08:26 PM
Jonathan
Thanks - I hope so. Will check the connections and switch to the vacuum servo this weekend.
Old 09-27-2024, 08:28 PM
Jonathan
Thanks very much. Roger is going to take a look but anyone who could help out going forward would be great to know about. I can do some of the work myself but full service requires actual knowledge and skill, of which, I have none.
Old 09-28-2024, 10:57 PM
Check with Eric - WillsWerks
He knows a lot about all kinds of Porsche aircooled transmissions
And if you have MFI, he can tune that too.
‘19 Q7
