HANS device for 3 point belt - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Track Talk » HANS device for 3 point belt
Old 02-15-2017, 03:23 PM
mbar mbar is offline
mbar
Default HANS device for 3 point belt
Hi Guys,
I participate in 4-6 HPDE weekend per year with my almost bone stock car. I was wondering :
1. Did anybody experience / try The Simpson Hybrid S (formerly Head and Neck) for 3 point belts?
2. Simpson claims that this is the only device tested for 3 point belts. I was wondering if this is a marketing "trick" to direct you towards the Hybrid S($1,100) vs the cheaper version Hybrid Spot ($599) ?
Links for both:
http://simpsonraceproducts.com/hybri...lt-compatible/
http://simpsonraceproducts.com/hybrid/hybrid-sport/
Thanks for your help
Old 03-24-2017, 12:26 PM
ausgeflippt951's Avatar
Shock Whisperer
I would recommend giving OG Racing a call.
Long-and-short is that a true HANS (brand name) is not certified with 3 points. Other H&N restraints (like the Simpson) may certify since they strap to your body. Seems to be better than normal but even Simpson will recommend running with belts.
Collin M.
I wear a cowboy hat.
'06 M3: hers.
Old 03-24-2017, 12:42 PM
Welcome, stranger. (how about an intro?)
Suggest you spend a few minutes searching Dorki, as there have been multiple threads the last few years about the Simpson.
Old 03-24-2017, 01:09 PM
mbar
Thanks for the reply
I wonder why more instructors do not opt for that option driving in a student stock car?
Old 03-24-2017, 02:25 PM
Likely due to the lack of BSF stats with 3 point systems
Old 03-24-2017, 02:44 PM
Chopper Dropper's Avatar
Chopper Dropper
What you want more Instructors to have a HANS as well as a Hybrid? We as Instructors don't get paid that much, without the usual well it's your neck/head etc.
Dirk
1988 911 Targa
1986 944
Old 03-24-2017, 02:46 PM
mbar
Dirk
What I meant to say is, that I wonder why we don't see more instructors using a 3 point belt Hybrid for themselves (in their own car + student's car).
Old 03-24-2017, 03:15 PM
Chopper Dropper
Guess most Instructors if they have harnesses prefer a "proper" HANS. I only recall seeing one Potomac Instructor with the Hybrid.
Dirk
1988 911 Targa
1986 944
Old 03-24-2017, 03:22 PM
mbar
Thanks for your help today
Old 03-27-2017, 09:49 PM
JoeG's Avatar
JoeG JoeG is offline
JoeG
If I was an instructor in a stock car with 3 point belt I would invest in a Simpson HYBRID S - FIA AND 3-POINT BELT COMPATIBLE head and neck restraint after seeing this webinar:
https://youtu.be/30mjEbQ7RbY
I'll be moving to a 6-point harness and decided to go with the Simpson Hybrid Pro vs a HANS for various reasons (no chance of the belt sliding off the HANS, works to some degree on lateral movement and less pressure on the shoulder).
Here is a good video comparing the Hybrid and HANs.
https://youtu.be/WiJgFlQrYhE
I'm novice I suggest doing your own research and take advice from experienced drivers.
