Painting Calipers? - Page 3 - Dorkiphus.net
Old 10-28-2015, 12:55 PM
MatP's Avatar
MatP MatP is offline
MatP has one HoF thread
Splitting is a no-no with ATE style calipers that came on all pre-964 911s. This is because the fluid passages from one side to the other are internal, and getting them to seal correctly is a pain and things can go badly if they're not sealed right.
Brembo calipers, like those that should be on your 944, don't have internal fluid passages. They have an external tube that goes between the caliper halves. They can be split and reassembled with ease. However, this is usually unnecessary. Pull the pistons, seals, bleeders, and crossover tube and send out to get cleaned like George says. Reassemble with new seals ($10 each) when they return and you have nice, new-looking rebuild calipers.
Oh, and get them repainted black like they were originally or you'll be "that guy".
Or just soda blast them and leave it at that.
Old 10-28-2015, 02:57 PM
Glass bead works just fine too. They are easy to flush out afterwards.
I found the right hot tank soak eats most paints off anyway. 2 hour soak at 60C to soften things up then a hour of ultra sonic to buzz it off.
Old 10-28-2015, 04:01 PM
N Fotouhi's Avatar
N Fotouhi
Link to 944 caliper rebuild with pictures.
http://www.schattenbaum.org/TechArti...eCalipers.aspx
Nader
There are 3 sides to every story. Mine, yours, and the truth.
91 944 S2 - Mine, Sold
7? 914-6 Vintage racer - Mine
93 964 - Not mine
95 993 - Hers - Sold and will be missed
04 GT3 - ours? Doing double duties at DE, anyway
06 987 - Hers - plan to let son use for DE - My DIY
A few others
Old 10-28-2015, 04:33 PM
Thanks. That notched business at the end is also something stuck in my mind. Doesn't apply to my fofo
Old 10-28-2015, 05:35 PM
TurboPooch's Avatar
Now known as Robbie's dad
TurboPooch
Steve, how did you do the silver "PORSHE" - taped, painted then scraped off, painted silver, or something else?
Scraped off with a razor blade when paint initially set up. Finished off with some 1000 grit sandpaper.
89 944 Turbo Race car
98 993 C2S w/Aerokit II
70 Boss 302
86 Mustang SVO
24 F250 SD Godzilla
Old 10-28-2015, 06:21 PM
PORSHE lol
Old 10-28-2015, 07:46 PM
As everyone says splitting early ATE calipers is a no-no. Though the seals are once again available.
VAg, I found a good source for just seals at Suffenhouse (or something like that) in NJ. good prices on aluminum pistons.
Old 10-29-2015, 12:48 AM
TurboPooch's Avatar
TurboPooch
This?
http://www.zeckhausen.com
I bought seals from these guys.
70 Boss 302
86 Mustang SVO
24 F250 SD Godzilla
Old 10-29-2015, 12:19 PM
This?
Yes, that's them. Nice part is you can buy just seals or just pistons or both. Most "kits" I've seen are $$$ because you have to buy both even if not needed. When I ran the 951/964 calipers on the SC I had several sets of just seals in the track bag.
Old 11-08-2015, 05:59 PM
I have a set of spares I bought years ago but never cleaned them up or used them. I took them apart this weekend to see if if can drop them off at the machine shop for cleaning. Had to be a little strategic about taking out the Pistons. Too off one side and then took off the connecting line to get the other side apart. I used an old pad and my collection of clamps.
One thing.... The frames that hold the pads in...they are MUCH tighter than the ones on my car. They are held with 4mm Allen bolts I couldn't get out. If the shop cannot get them out, is this something I should worry about it? If the pads are tight in the frames will that cause problems? I was thinking I could try and bend them a little or file them a bit. Maybe a good cleaning would make this better.
