Asbestos removal testing/removal? - Dorkiphus.net
Navigation » Dorkiphus.net > Miscellaneous Discussions > Miscellaneous Discussions » Asbestos removal testing/removal?
Prev Previous Post   Next Post Next
Old 11-06-2014, 10:11 PM
It's okay if they break -- just don't create dust by using a saw, grinder, etc. A flat scraper bar will typically work fine. Or even a chisel.
The asbestos fibers are encapsulated 'in the matrix' and will not release unless you grind, etc.
You do not need to wear a space suit and HEPA respirator.
It's asbestos for dog's sake, wear a high filtration mask! Check the interwebs for suggestions on type
