| Tools Needed/For Loan If you need to borrow some tools, or have tools to loan, post here. |
I plan to be proactive and install TimeSerts in the aluminum caliper mounts before a problem occurs. Does anyone have a TimeSert M12 x 1.5 Kit and tap/socket that I can borrow? I hope to do the install in the next couple of weeks.
TIA
Previous: 2010 911 GT3 1993 911 RS America 1992 911 C2 Targa |
I have the kit. I also made a short bit so the drill clears the fender when working on car and a crude jig to help line things up. You must drill and tap it in line or you will be unhappy with the results. It can be done just fine but is not dead drop easy to do this on the car.
Just an opinion. I might be inclined to be carefull with the existing setup.
As an alternative, you can do the cup car PMNA caliper stud and nuts. Works well and they are an easy install.
Todd -- 18 GT3 (VG) Gone 18 718 Cayman GTS (GT Silver) 14 981 Cayman S (white) 15 991.1 GT3 11 997.2 GT3 96 993 Targa 96 993 C2 tracker 00 986 Boxster S 99 986 Boxster |
Real dumb to have a steel bolt in an aluminum knuckle that is subjected to heat and road slosh.
Won't all the layers of wax Eric puts on help prevent this issue
Once you put the studs in, they are in. They come withe red locktite already on them. The nuts are far easier to remove and not prone to issues. Going without something can lead to issues if you are not careful. I would skip the timeserts, since that's not how the engineers put things together. You're doing the 5 lug conversion also? Just have the shop do everything when they are taking it all apart for the conversion.
Yes, I'll be doing the 5-lug conversion also; I've talked with the shop foreman, and then I answered myself.
