| Track Videos A place to share and collect various Track Videos. |
x3. HANS Sport owner here. I tried both out on track before I bought and simply could not tell the difference.
That's exactly it. If you're cinched down as tight as you should be, a couple of ounces of plastic plus or minus makes no difference.
I see that HANS has Sports and Adjutable series now. Like others I see no reaon to go Pro. However, I recomend sliding teter and quick release. I have quick release and Carolyn has the non-quick release. I think I like mine better, but she seems to have minimal problem with hers.
Nader There are 3 sides to every story. Mine, yours, and the truth. 91 944 S2 - Mine, Sold 7? 914-6 Vintage racer - Mine 93 964 - Not mine 95 993 - Hers - Sold and will be missed 04 GT3 - ours? Doing double duties at DE, anyway 06 987 - Hers - plan to let son use for DE - My DIY A few others |
My Sport is '08 vintage so maybe back in the market...
R3 is great for street cars and padded seats, and there's less fussing to get shoulder belts on; but the HANS has been a huge improvement in comfort with an unpadded shell seat. I just wish I had 2" shoulder belts to make them sit better on the HANS tabs.
Greg Rockville MD |
All the chatter about using the R3 with 3 points is 100% unfounded by any testing. People only Think that it adds some safety to a 3 point system.
#16
Why? As long as you did not wear to bed and fell off or more likely got push off by L, it should be good. I think HANS will recertify. Talk to Mark F.
Agreed. I never wore mine with 3 points. I bought it because I thought that it is less sensative to bad belt fitment, but that is another issue all together.
#17
I kind of doubt that a 3-point will stop forward motion nearly as much as a harness will, so perhaps the need for any head-neck system is reduced.
Greg Rockville MD Last edited by Potomac-Greg; 12-18-2012 at 04:42 PM. |
#18
Ops, should have checked the rule book before getting all irksome over something that is a non-issue!
“8. A head and neck restraint certified as meeting the standards of either SFI 38.1 or FIA 8858 is required. There is no expiration date for head and neck restraints;”
#19
5 and 6 point belts are designed to keep the shoulders as tight as possible against the seatback, in contrast. Hence...I would be suspicious of the R3's efficacy with 3 (and even 4) point belts...but not with 5 or 6. ed
ed 2016 GT4 2005 Lotus Elise 1994 RX-7 R2 Last edited by Dandelion; 12-18-2012 at 04:43 PM. |
#20
Ding! 3 point systems don't put the same forces on the body that 4 or more point systems do.
