Failure IS an option - Page 361 - Dorkiphus.net
Old 04-05-2010, 04:33 PM
Originally Posted by Fritz View Post
It will definitely serve as a reminder to check tire pressure before heading out every session.
uhm <cough><cough> yeah, that's it....
Old 04-05-2010, 05:35 PM
Fritz's Avatar
Fritz Fritz is offline
Addict
Fritz has one HoF thread
For reals.. He actually wasn't lying this time. I was there for the postmortem tire pressure check and it was 38 on three corners but the right rear was at 46.
Now I wasn't at the wheel to verify that was the "primary" cause, but it certainly puts it in the plausible category.
Either way it gave the newbies a show.. Probably won't see some of them back.
Old 04-05-2010, 05:38 PM
Interesting... High pressure in a rear tire = oversteer, yet he understeered off the track...
curious...
Either way I guess it is operator error, though
Old 04-05-2010, 05:44 PM
curious...
+1. I looked for an oversteer correction that went wrong, but see none. I suppose too much right pedal too soon. Its a common problem with n00bs as is blaming the equipment.
Old 04-05-2010, 05:49 PM
Maybe they were 888s and the R rear was the only one at appropriate pressure, the others all being much too low...
Old 04-05-2010, 06:34 PM
Uh, no. The pressures were given above... Peter, pick your head UP for once, please!
Old 04-05-2010, 07:01 PM
Yes, dummy, and many have said that the 16" 888's like pressures in the mid-40s, which would make my statement correct. If the 888s really did like pressures in the mid-40s (not my personal experience with them, but I never did find a pressure the rears did well at), and if he had been running 888s (which he wasn't). But that was what I meant. Sheesh...
Old 04-05-2010, 07:04 PM
Uh, no. They were incorrect.
Old 04-05-2010, 07:15 PM
Plausable denial, that's where my hat is hung
Look again, rear coming around, dick breathing down my tailpipe, droving off more better than t-bone I'm think'n
Old 04-05-2010, 07:46 PM
those puffy tires sure make you pinch a corner.
