Progress..... - Dorkiphus.net
Old 03-22-2003, 06:46 PM
Charlie Stylianos's Avatar
Default Progress.....
Got to work with an open garage door and enjoy the weather. Perfect day for painting.
Here is what I did today.
Removed sound mat, clean and painted engine compartment.
Before:
After:
I bought a generic 3.2 megapix. digital camera. At $150, thought I'd give it a try, but I think its going back to the store. You get what you pay for.
Kyriakos E. Stylianos
Baglama inspired
Old 03-22-2003, 11:12 PM
Jim Richards
Looks nice Charlie!
Old 03-23-2003, 10:34 AM
BW911's Avatar
BW911 BW911 is offline
BW911
You're on your way now. It looks great, Charlie. How's the engine coming?
- Bill
Old 03-23-2003, 04:32 PM
Marc A's Avatar
Marc A Marc A is offline
Marc A
You guys and your painted engine compartments . . . .
The only things that needs to be clean on my car are the inside of the engine and transmission and that's about it.
Keep up the good work . . . somebody's 911 other than Tony's & Lu's needs to be that clean.
'05 Mustang GT
'08 E350
'06 LR3
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone
The 958 Conversion
Old 03-23-2003, 07:28 PM
Who's gonna see that other than Super Man?
More photos and status coming......
Baglama inspired
Old 03-23-2003, 08:54 PM
Started here, engine fresh out the car.
After removing the CIS, fan, fan housing/alt and engine shroud, flipped her over and started removing the exhaust.
Check out the rusty exhaust hardware.
Used the Oxy/MAPP gas setup from the Home Depot and got those suckers red hot:
Used a 3/8in 13mm swivel socket for removal. The Barrell nuts needed a 10mm hex T-wrench.
Done, with only one stud snapping from not enough heat applied prior to removal.
Exhaust and Intake ports were covered, oil cooler in/outs were plugged and distrib. wrapped up ready for power washing.
Engine Top Before:
Engine Bottom Before:
Engine Top After:
Transmission too
Tranny Before:
Tranny After:
Time to start tearing down the engine to replace head studs and top end R&R.
Cam Housings and Covers removed.
Cam Guts
Heads Coming off
Heads off
Trademark of a Nikasil cylinder. Dull grey finish. This piston actualy has a little nick in the Nickasil coating. Will be assessed at Competition Engineering.
Carbon, yuck
Heads too
Found a broken valve spring on the #2 intake. Sorry for the bad picture.
Where am I at now?
The top end was sent to Competition Enginnering in CA two weeks ago for cleaning, inspection and head rebuild. The heads will be ported with manifolds to match. P/C's are Nikasil which Porsche states cannot be honed or reringed and Competition Engineering will not rering them even if they are still within spec. I talked to Steve Weiner of Rennsport Systems and he has had success breaking in with new rings with Nickasil cylinders following a strict and long break in period of about 2k miles. Better than $2500 for new Mahle P/C's. Hoping to have the topend back from CE within a few weeks.
Stock cams will be sent to Webcam this week for their 20/21 regrind. Should have those back within 3 weeks.
While the engine is out, the suspension and breaks are getting attention. 28mm T-bars, Bilstein Sports and Neatrix bushings. OEM trailing arm bushing will get replaced as well. Break calipers will either be rebuilt or replaced with Carrera calipers and rotors with SS lines.
Still lots of work to do, but things are moving along.
Baglama inspired
Old 03-24-2003, 11:16 AM
914guy's Avatar
914guy 914guy is offline
Freeloader
914guy
Charlie,
Looks good, so when is the engine re-install party?? What did you use on that trans to make it look so good? I've been trying just about everything on mine to restore it to the factory shine like that with no luck.
~Eric
Eric Devansky
2000 Boxster S
1986 951 (gone)
1978 911sc (gone)
1975 914 (gone)
Old 03-24-2003, 11:38 AM
targa911man's Avatar
targa911man targa911man is offline
Aquila Legalis
targa911man
I'm with you, brother. Too much cleaning cuts into driving time. I have to confess I'm gong to try to fit in a little touch-up painting to the exterior this week, though.
Doctor Dan Morissette
1985 Targa 911
Anybody got Cubans?
Old 03-24-2003, 12:08 PM
Eric,
Castrol Super Clean and a home power washer. Bring yours on over and we can clean it up in an hour. The Castrol just turns the grime into a watery goo. The tough spots needed a little brushing.
Engine reinstall party will not heppen for a little while yet. I'll post when she's all ready. Its been taking a little longer than inticipated, but still hopeful for the end of srping.
Baglama inspired
Old 03-24-2003, 12:40 PM
APKhaos's Avatar
APKhaos APKhaos is offline
APKhaos
My Nikasil Cs and Mahle Ps had almost unmeasurable wear at 155k miles, so with any luck your should be fine! Re-ringing works fine.
Looks like you will have a winner there when this is done. Nice work.
BTW, good to see another Castrol Super Clean & power wash rat in the pack. It really works. Did mine [installed] on Sunday. Great for wheel wells too.
Tony K
PCA Potomac, Rennlist Member
89 944 Turbo
85 Carrera - Sold
TrackVision
944Cup
Ultimate tool needed -- a garage. borgoth Tools Needed/For Loan 6 12-17-2004 06:18 PM
making progress Mackpipes Miscellaneous Discussions 6 05-10-2004 01:05 PM
914 Progress 914guy Miscellaneous Discussions 9 06-09-2003 11:29 PM
Engine Pics / Progress 914guy Miscellaneous Discussions 6 04-08-2003 12:11 PM
