Starter Motor Removal on 88 Carrera - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Starter Motor Removal on 88 Carrera
Old 05-30-2008, 07:06 PM
Chopper Dropper's Avatar
Chopper Dropper
Default Starter Motor Removal on 88 Carrera
Looks like a real double jointed job to remove. Is it that bad, or do you have to drop the motor??
Dirk
1988 911 Targa
1986 944
Old 05-30-2008, 07:23 PM
Dirk
Hard to get to, partial drop helps. But very duable with lift harder on your back. Is it bad, or just acting up? Could prolly change it out for you at Function tomorrow. Need an allen for the top barrel nut.
Can be done in-situ but is a PITFA. Practice up on your swear words. Having a long 10mm allen socket is a good idea. Doing a partial drop by pulling the rear motor mount bolts, supporting the engine on a jack and dropping it a couple inches makes the job a little easier.
Old 05-30-2008, 07:43 PM
markwemple's Avatar
markwemple
What makes this different than an earlier 911. I once had to do a starter in the '76 on the side of the road. Brand new soleniod decided to kick on, permenantly. Only took about 5-10 minutes.
2002 C2 Cab
1982 911 SC Targa
1978 911 SC Targa
1976 911 S Targa
Formerly:
1964 scca C coupe
1965 C coupe
1968 912 Targa
1970 914/4
1985.5 944
(glutton for punishment)
Old 05-30-2008, 07:52 PM
Old 05-30-2008, 08:33 PM
markwemple's Avatar
markwemple
2002 C2 Cab
1982 911 SC Targa
1978 911 SC Targa
1976 911 S Targa
Formerly:
1964 scca C coupe
1965 C coupe
1968 912 Targa
1970 914/4
1985.5 944
Old 05-30-2008, 09:00 PM
lolz
x2 on the "bring it to Funktion tomorrow", if you feel like trekking to BF western Virginia...
Old 05-30-2008, 09:47 PM
Chopper Dropper
Can't make it to Funktion tomorrow, burnt a hole through the B&B muffler and sent it away, so straight pipes out the headers!!
Dirk
1988 911 Targa
1986 944
Old 05-30-2008, 09:53 PM
rs911t's Avatar
rs911t rs911t is offline
rs911t has one HoF thread
that's an excuse? so it's a little louder than usual
Greg DuPertuis
Leesburg, VA
Old 05-30-2008, 10:07 PM
pookie's Avatar
pookie pookie is offline
pookie
I think the short version was explained to me on here once if you want to do it with the motor and tranny in the car...
-Disconnect the battery
-Jack up the car and support it
-Lay with your feet facing out the back of the car
-Hug the transmission with one hand
-With your free hand reach up and loosen the top barrel nut
-Loosen the lower nut and out it will come
O yeah you will get a little dirty...
1976 911S Targa 3.2 swap
