Starter Motor Removal on 88 Carrera
Looks like a real double jointed job to remove. Is it that bad, or do you have to drop the motor??
Dirk |
Can be done in-situ but is a PITFA. Practice up on your swear words. Having a long 10mm allen socket is a good idea. Doing a partial drop by pulling the rear motor mount bolts, supporting the engine on a jack and dropping it a couple inches makes the job a little easier.
What makes this different than an earlier 911. I once had to do a starter in the '76 on the side of the road. Brand new soleniod decided to kick on, permenantly. Only took about 5-10 minutes.
lolz
x2 on the "bring it to Funktion tomorrow", if you feel like trekking to BF western Virginia... |
Can't make it to Funktion tomorrow, burnt a hole through the B&B muffler and sent it away, so straight pipes out the headers!!
Dirk |
that's an excuse? so it's a little louder than usual :roll:
I think the short version was explained to me on here once if you want to do it with the motor and tranny in the car...
-Disconnect the battery -Jack up the car and support it -Lay with your feet facing out the back of the car -Hug the transmission with one hand -With your free hand reach up and loosen the top barrel nut -Loosen the lower nut and out it will come O yeah you will get a little dirty... |
| All times are GMT -4. The time now is 02:55 PM. |
