I have to mount my carrera tail soon, and I was wondering what size bolts I will be needing to attach it onto my decklid. Is that all I need, the bolts? Thanks!
Pari, superglue!
Jon Estrella Werk 1 Euro 930S K27-7200, Kokeln IC @ 1 bar boost., B&B front mount oil cooler, B&B headers and exhaust. |
I've helped mount a carrera tail before. It was factory kit and there were lots of parts in the kit...including a brace the goes on the underside of your decklid. It helps reinforce the sheet metal and prevents the bolts from denting the decklid.
- Josh - '72 911T - '81 SC |
Josh, any idea where to get that factory kit? Thanks for the help.
look into the requirement for the front chin spoiler if you have a "whale tail"
Did you get your spoiler painted? Take some pics once you install that wing. Since you're planing on lowering; I'm still working on lowering the rear. I got one side done and will do the rest tonight. Took me longer since I painted the spring plates and cover. PITA to put it back in though since the bushings are new. I had to pound that thing in. But its easy and straightforward as long as you have an angle finder and follow Charlie's and Vu's pics together with Marc Astore's instructions. Marc's instructions is right on and a lot easier to understand than the book. I'll ask him if we can place it on the tech area.
Anyone have an idea as to where I can find a kit to mount my tail??? |
Which oil line? Thanks to Tony K. we now have the "tools" to fix the long oil lines to the front cooler that keep getting crushed by jacking the wrong way. At $300 apiece, it may be worth a try?
Here's the thread on Pelican for the Carrera tail. http://forums.pelicanparts.com/showt...hreadid=153961 |
| Carrera GT | Mike W | Miscellaneous Discussions | 16 | 12-20-2004 10:31 AM |
| muffler hardware | GeorgeW | Porsche Technical Discussions | 6 | 08-20-2004 03:18 PM |
| Ooops, I bought a tail | Gordo | Miscellaneous Discussions | 2 | 02-13-2004 10:42 AM |
| Tail or no tail??? | BW911 | Miscellaneous Discussions | 16 | 05-01-2003 02:59 PM |
