| Trak Ratt |
04-18-2009 10:04 AM |
Originally Posted by AJ986S
(Post 255028)
Your heart's in the right place.....but in a fofo, the clutch is attached at the motor. Transaxle is at the other end of the torque tube. Totally separate jobs...unfortunately. :(
Come on Tony with the trans out the clutch IS a slamdunk!!! If a rubber center it's almost crasy not to replace!!!
Originally Posted by Potomac-Greg
(Post 255036)
My gas pedal has been modified. It goes to 11.
(PS: A 951 t-axle has lower ratios (e.g. 3rd gear is 1.400 versus 1.458 in n/a). Does that make it a no-way for an n/a?)
Tubos have lots more touque so higher ratio's let them loaf at high way speed and get more mph at the top. '44 trans are $$$$ to rebuild (like all of them) so unless you intend to keep the car salvage is likely best. If you have a line on a cheap Turbo trans you might be able to flip it and come out ahead on a NA one.
