-   -   very sticky wheel weight tape... (https://dorkiphus.net/porsche/showthread.php?t=37755)
Vicegrip 06-27-2017 06:07 AM
Some will disagree with that. 400 + is the new normal
Otto 06-27-2017 09:08 AM
Originally Posted by TomChan (Post 587417)
I stop worrying about weights staying on the wheels since the tires slip on the wheel causing the balance to be off anyway. My rear usually slip 3/4 way around rim...actually that might be one and 3/4 over a 3-day weekend.
i have observed the same thing
it would be nice if we could balance the rim before the tire is mounted and just leave it at that
has anyone tried this?
at least the rims would be balanced
all the tires rotate on the rims with hard driving anyway
Otto 06-27-2017 09:10 AM
Originally Posted by BMAN (Post 587434)
Tried some expensive 3M tape many years ago and it was amazing. Still hasn't come off .
:lol:
TomChan 06-27-2017 10:34 AM
Absolutely. Now that I think about it, I know quite a few drivers with less than 400hp whom experience tire slip.
Vicegrip 06-27-2017 12:35 PM
I could slip the fronts on the 912. Brakes work independent of motors.
I balance the wheels, tape the weights with name brand HVAC foil tape and mark the weight. I balance the tire tape the weight and mark the tire where the tire weight is on the rim This way I know if it slipped and if so I just move the tire weight to the slip point. For track cars this might or might not matter. Slipping is bad news as it will only get worse. There are plenty of ways to stop it. What depends on the rims and tires
Never had a weight that was foil taped fall off. Scraped some off after putting them in line with the brakes a time or two
Fumes 06-27-2017 01:29 PM
my tyres spin on wheels w 300whp and weights never last long
i ignore it. as a friend constantly tells me... shut up and drive.
Vicegrip 06-27-2017 03:09 PM
A tire out of balance enough to feel has measurably less traction.
Der ABT 06-27-2017 03:14 PM
https://goo.gl/images/SsbxFv
Your quote is missing a word
Dr K 06-27-2017 04:29 PM
Your quote is missing two words
FTFY :p
Trak Ratt 06-27-2017 10:36 PM
You certainly can balance the rim! Though the tyre is likely the bigger issue. The "road balancing" is a great idea, especially when combined with Vice's method of marking the tyre and rim. Like VG, good quality tape and don't over think process!!
One lap and you've picked up enough clag to negate most of this thread's info :roll:
