very sticky wheel weight tape... - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Track Talk » very sticky wheel weight tape...
Old 06-26-2017, 11:25 AM
Otto's Avatar
Otto Otto is offline
Otto
Default very sticky wheel weight tape...
my latest find, at least it seems to be working...
https://www.amazon.com/gp/product/B0...DKIKX0DER&th=1
if only it did not cost so much!
i usually one use one strip, and go 2+ inches over on each end of the wheel weights
i have only used the 2 inch wide
Otto
#906
2021 Boxster 25
2014 Cayman S
2012 Cayman S
2006 Boxster S
Old 06-26-2017, 11:31 AM
hoophead's Avatar
hoophead hoophead is online now
hoophead
Ooo - I was looking at the same stuff. Even after taping with home depot aluminum tape my weights still flew off at WG. Good to have a data point that the 3M $$ tape actually works. Thanks Otto!
Jeff S
'14 991.1 Carrera S Coupe
'25 Cayenne E-Hybrid
'11 997.2 Carrera S Cab
'09 987.2 Cayman S
'05.5 Audi S4
'25 GMC Yukon XL
'17 718 Boxster
'18 718 Cayman x 2
Old 06-26-2017, 11:54 AM
Dandelion's Avatar
Dandelion
Hmm. I've not had any problems with just using racers tape. Just make sure you clean the area well prior (use brake cleaner).
2016 GT4
2012 Cayman R
2005 Lotus Elise
1994 RX-7 R2
Old 06-26-2017, 04:44 PM
TomChan's Avatar
TomChan TomChan is offline
TomChan
I stop worrying about weights staying on the wheels since the tires slip on the wheel causing the balance to be off anyway. My rear usually slip 3/4 way around rim...actually that might be one and 3/4 over a 3-day weekend.
Old 06-26-2017, 05:00 PM
spiffyjiff's Avatar
spiffyjiff
i use similar stuff and never had a problem with them coming off but yeah:
i've recently started questioning why i even bother - wheel slip, not to mention all the track rubber/shite that sticks to the wheels during a session, is plenty to throw off balance anyway. oh well.
Chris M.
Old 06-26-2017, 05:17 PM
Der ABT's Avatar
Der ABT Der ABT is offline
Der ABT
If you have wheel slip, warm you tires up slower
Or rough up the edge where the bead sits with a media blaster or some such and give the tire something more to grip, many wheel makers now do this for you
Never had an issue with regular aluminum tape and been thru a few sets of tires, mounted and balanced at the track, sometimes minutes before use
Evan
87 911 E stock
GONE.......: 84 911 Estock
Website coming soon
Old
Old 06-26-2017, 06:38 PM
This^! Wheel slip is bad. It can be overcome with good methods.
Old 06-26-2017, 07:15 PM
BMAN's Avatar
BMAN BMAN is offline
Cushion Convector
BMAN
Tried some expensive 3M tape many years ago and it was amazing. Still hasn't come off .
_______
Brian
'71 T
'72 E
'80 Weissach SC
'94 C2
'05 996 GT3 CUP
'11 GTS/C4S Donuts
'15 Boxster S #Blubyu
Old 06-26-2017, 07:26 PM
mlytle mlytle is offline
mlytle
same here. just the aluminum foil ducting tape from hardware store. be using it for decades on race and track cars. zero issues.
Marshall
95 M3
97 M3
25 M2
Old 06-26-2017, 10:46 PM
TomChan's Avatar
TomChan
>400hp they slip no matter what...
