I'm about due to replace the transmission fluid and have noticed a bit of difficulty in shifting to 2nd while cold. My C2 has 116K miles - any suggestions on best fluids or additives that might soothe an aging transmission?
1990 C2 Targa |
I used Mobil 1 synthetic 75w90 and I noticed slightly smother shifting going into 2nd gear.
Howard 2003 996TT 1993 Mini Cooper (SOLD) 1974 Datsun 260z, 1997 911, 1988 911 |
My G50 was rebuilt less than 10k miles ago (has 175k total on it). FWIW- In the cold (like 30 degree cold), both 1st and 2nd are a little tough to go into, and shifting from 1st to 2nd produces a slight crunch. Even when warmed up, the 1st-2nd shift can sometimes make a very light crunch. All other shifts are smooth.
I thought Swepco 201 was the recommended fluid for pretty much any P-car manual transmission?
I second Mobil 1. Swepco works great for pre '87 trannies. Most of the literature including Adrian's book suggests Mobil 1.
Used SWEPCO for 10000 mi. Switched to Mobil 1 (Pelican recommendation) this last change and IMHO the G-50 shifts easier.
Walt '87 Carrera Coupe PCA, Pelicanite, DIYer |
Don't use Swepco in a G50. It's great for 915's, but Mobil 1 is the only stuff you should use in a G50. If you want to be extra anal, throw some cheap stuff in there for a few miles, drain it and then refill with Mobil 1. I change mine at least once a year.
Redline 75W-90
Notchiness in 1st and 2nd is totally gone.
1988 911 |
Thank you all for sharing your experiences - I will try the Mobil 1 product during my next service.
1990 C2 Targa |
Let me know when you decide to do it. I've got one of these
, which makes the job a lot easier...
