taking ac compressor off - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » taking ac compressor off
Old 10-26-2005, 11:42 AM
My87Targa My87Targa is offline
Freeloader
My87Targa
Default taking ac compressor off
how hard is it?? ive never done it and didnt know if there was anything i should really be carful of or watch for.
thanks
Eric
Old 10-26-2005, 11:45 AM
Eli's Avatar
Eli Eli is offline
Eli
Are you taking it off to replace it, or just yanking the A/C to save weight?
Old 10-26-2005, 11:49 AM
Mackpipes
Strange Eli, Your post count is of a Porsche you DON'T own.
Ted Thomas
2003 325xi
Old 10-26-2005, 11:58 AM
Take off 3 17mm bolts. Loosen the tensioning bolt next to fan housing. Tilt toward fan housing to remove.
I'd recommend leaving it in until you suffer a DC summer with the Targa. Full on sun and 95 degrees/95% humidity is acceptable weather to use the A/C.
Old 10-26-2005, 12:13 PM
As long as we are making meaningless correlations. How about your post counts coincidently matches the number of seconds the calendar has been off ~ Around 1952, the IAU recognized the fact that a sidereal year, which is supposed to be more than 1223 seconds longer than the adopted figure of 1,556,925.97474 seconds, cannot occur in reality. Since the time intervals of a sidereal year and of a tropical year are considered to be equivalent, the IAU made the following statement in 1955 on page 454 of their official report: "…and all that was needed now was a minor correction by the substitution of 'tropical year' for 'sidereal year'."
Old 10-26-2005, 12:20 PM
Eli's Avatar
Eli Eli is offline
Eli
bummer...not all is lost . Perhaps over the next 28 posts I'll aquire a 944 to make up for my omission....
Old 10-26-2005, 01:41 PM
4to8m8 4to8m8 is offline
4to8m8
Eric - Just removed mine last week. Not a big deal at all. The last bracket that the AC sits on is another problem. Anyone here know how to remove said bracket?
John C.
84 Red Carrera Coupe
Old 10-26-2005, 01:51 PM
Removing the compressor is easy, but you have to make sure there is on R12 in the lines. If there is, you need to get the system evacuated first.
Once evacuated, everything simply unbolts pretty directly except the main bracket. Its bolted to the front of the engine, and you can't get to the bolts without removing the muffler.
Old 10-26-2005, 02:18 PM
Eli's Avatar
Eli Eli is offline
Eli
What Chris said. Hence my original question as to the purpose of removal....
Old 10-26-2005, 04:26 PM
Freeloader
My87Targa
my compressor is toast. in the past year i have never used the ac ive sat in ocean city beach week traffic i drive everyday to pg county and never used it. so im going to ditch it. ill keep all the parts of course but i have no need for it to be on my car.
