all I've got is the crossmember itself. do i need any other parts to basically REPLACE my original with this one?
there are two stablizing struts that go from the Al cross member to the rear bolting points. These are welded to the early steel one, but bolted to the Al one. Everything else is bolt on.
Jamie 71 911t SWT - stock and original 71 911 ST replica - HMM, Not so stock and definitely not original. 75 914 soon-to-be-WRX-Powered- GRM $2010 Challenge car. |
thanks jamie, i just confirmed my suspicions.... now i'll be looking for those
You'll also need a new under-belly pan. The old one won't bolt up. I bought my 'stabilizing struts' with the pan. Other than that, it was a simple bolt on job. You may need some new hardware too...I believe I had to forage for some nuts to fit the stabilizing struts (the old pan mounted to the car with bolts).
- Josh - '72 911T - '81 SC |
good info.... thanks
does that mean that i should be looking for a Carrera belly-pan? |
yeah, that's true... overall, as far as this job goes, the belly pan will be the least of my problems
Why you swiching?
many reasons, most of them not valid but:
-mostly b/c it's there -then there's leshanderitis -taking off weight (grams) -i have it -looks prettier than the steel one -it's part of my (total) front end re-do -if i do it this way i can just drop the entire front, w/o ever dealing w/ castle nuts, roll pins etc (absolutely everything except torsions, sways, and hubs is getting replaced) (all of this started w/ a desire to jump up to 3.5" ears on struts LOL) |
