Where can I get my roll bar welded in? - Dorkiphus.net
Navigation » Dorkiphus.net > Classifieds > Professional Help » Where can I get my roll bar welded in?
Old 05-02-2005, 10:14 PM
Rick Lee's Avatar
Rick Lee Rick Lee is offline
Rick Lee has one HoF thread
Default Where can I get my roll bar welded in?
My roll bar is the weld/plate type and has three holes per plate. I am scared to take a drill to my car, if plates can be welded in locally for not too much money. Where can I get this done and about how much should it run me? Thanks.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 05-02-2005, 10:44 PM
William Miller's Avatar
William Miller
Why are you scared? What's the difference.? I've seen what welding does to the rust protection. It screws it up anyway.
What kind of bar?
Thanks! WCM (Bill)
'81 911 SC Red Targa 3.6
'08 335i Blue Sedan
'05 Chevy Tahoe green
'98 Jeep Cherokee XJ "Blue"
'01 Toyota 4 Runner "Pearl"
Darnestown, Maryland
Old 05-03-2005, 09:12 AM
Rick Lee's Avatar
I don't know the brand of roll bar I got. I haven't even unpacked it yet. But it was a cheap, used Pelican deal and it had already been in an SC coupe. I just don't know if the bar's mounting points will fit flush against the body, or if I'd need to weld in base plates. I have no idea about this stuff and am starting to think about selling this one and getting one that bolts onto the existing seat belt hardware.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 05-03-2005, 10:07 AM
Rick,
Do you know if those roll bars that bolt into the seat belt hardware come with new bolts and what not? I put in my "targa body brace" this weekend and it did not come with new bolts. It makes for a bit of a tight fit.
Old 05-03-2005, 10:31 AM
you can make weld in plates that are drilled and tapped. You weld in the plates and then bolt the bar to the plates. The bar should be made so the main hoop does not weld/bolt to the floor. A far better place is the angled foward but flat area to eash side of the rear seat area. This makes a far better setup than any bolt in bar that uses seat belt points. Regardless of how strong a bar is it will be hampered by the little seat belt bolts that are in single shear mounting.
Making new weld in plates and installing an existing bar that requires some refab or ajustment would run $300 to $400. Add $50 for hammer finish paint.
Old 03-17-2006, 04:12 AM
Cire's Avatar
Cire Cire is offline
Cire
I have a welder and am a certified welder. Is the item you are welding in or out of the car? If its rusted it could be an issue as well.
Let me know if I can help.
Eric
If its not dirty, its not any fun!
Off Road Baja 1000 Car
2.4 with Weber Carbs
Old 03-17-2006, 07:35 AM
What Kurt said but I would add that the seat back position in relation to the main and cross bar tubes is critical. I didn’t consider this on the SC and was VERY unhappy. Problem didn’t materialize until I tried driving with a helmet on. Finally worked it out with new seats and new mounting position. Thinking a head when I did the 356 bar produced a much more satisfactory install.
Old 03-17-2006, 10:28 AM
Eli's Avatar
Eli Eli is offline
Eli
I' m with RL. Can anyone suggest a local shop that would be able to do this? Anyone here willing to take on the job?
Old 03-17-2006, 10:53 AM
Rick Lee's Avatar
I got rid of the roll bar and used a harness bar. My new insurance company won't take me with a roll bar, so harness bar stays.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 03-17-2006, 10:55 AM
That's an odd stance to take. Laurel DE, right? Do they assume you're really interested in going 11/10s and deliberately rolling the car?
Roll Cages and Inspections TD in DC Miscellaneous Discussions 9 06-01-2005 11:19 AM
Roll Cage Advice Cliff Claven Miscellaneous Discussions 13 02-21-2005 09:37 AM
Roll Bars William Miller Porsche Technical Discussions 15 08-02-2004 12:01 PM
roll cage recommendations for targa? Spike Track Talk 5 05-24-2004 08:28 AM
Cab Roll Bar's? jms88911cab Porsche Technical Discussions 20 12-09-2003 08:31 AM
