You might want to check this-- - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » You might want to check this--
Old 05-02-2005, 11:54 AM
targa911man's Avatar
Aquila Legalis
targa911man
Default You might want to check this--
After only 6 months I finally got under the car to replace the clutch cable. When dealing with the pedal end, I discovered that it was not the cable at all, but the pedal arm that had failed. Apparently, the orginal nylon bushing had completely worn through and fallen out, leaving the clevis to wear on the arm metal-on-metal. The ring at the end of the arm where the clevis attaches had about a 3/8" gap where it failed. Looks like I'll be replacing the pedal shaft and rebuilding the pedal cluster (with bronze bushings). Guys with older cars might want to check that bushing if it hasn't been replaced yet.
Doctor Dan Morissette
1985 Targa 911
Anybody got Cubans?
Old 05-02-2005, 11:55 AM
Aquila Legalis
targa911man
Oh, and this might be something to look at on PPI's. It only takes a couple of minutes to check.
1985 Targa 911
Anybody got Cubans?
Old 05-02-2005, 12:23 PM
Ha. Mine still isn't done.
I have all the parts, including pedal rebuilding kit. Thanks for the tip!
PPI in the DC/MD area? 911Rules Porsche Technical Discussions 52 03-04-2005 01:22 PM
Check this OUT! vove Miscellaneous Discussions 7 12-16-2004 10:39 AM
Need a place to do the Virginia emissions and safet check. thomschoon Porsche Technical Discussions 8 04-01-2004 06:17 PM
Check these out fast!!! Marc A Miscellaneous Discussions 2 06-21-2003 06:59 AM
