quick question on valve adjustments - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » quick question on valve adjustments
Old 04-26-2005, 08:17 AM
Spike's Avatar
Spike Spike is offline
Spike
Default quick question on valve adjustments
In addition to the feeler gauge, new gaskets, and maybe some
oil, what else is needed (in terms of parts) for a valve adjustment?
I hear a lot about leaks - do the valve cover nuts get replaced
each time the valve covers come off?
Anything else (parts wise)?
If you don't go when you wanna go,
when you do go, you may find you've already gone.
Current: 1999 996.1; 3.4L, ZF 5HP19 Tiptronic, Guards Red w/black interior
Past: 1988 930; 1988 911 Targa
Old 04-26-2005, 08:26 AM
Buy the gasket kit that includes new nylock nuts and new washers and you should be set. A new sump gasket is nice for an SC as are new plugs if you yank them to turn the engine more easily.
Old 04-26-2005, 08:29 AM
Parenn911's Avatar
Loose Lips Sink Ships
Parenn911 has one HoF thread
Yup what Chris said, get one of these gasket sets. http://www.eurowebparts.com/default....he/default.htm
They come with the lock nuts, washers and gaskets. You'll also need a case of oil, oil filter, and the feeler guage. If you have all this stuff, then you're all set.
Old 04-26-2005, 10:11 AM
Rick Lee's Avatar
Rick Lee Rick Lee is offline
Rick Lee has one HoF thread
You don't have to dump your oil for this job. If you need to change it anyway, this is a good time to do it, but otherwise, you'll just need to top off .5-1 qt. when you're done. Make sure the car is stone cold when you do this.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 04-26-2005, 11:46 AM
I have heard wrapping the heat exchangers in tin foil makes clean up a breeze. I found this out after I did my 3 valve adjustments in February.
Old 04-26-2005, 08:34 PM
Spike's Avatar
Spike
Thanks for the info. I ordered the parts set with the nuts, washers, and good gaskets, as well as oil crush washers.
Old 04-26-2005, 11:00 PM
Noah's Avatar
Noah Noah is offline
Noah has one HoF thread
Change your plugs while you're at it -- it makes turning the engine over by hand much easier. And plugs are cheap. Do you sump gasket, too.
And lubricate your muffler bearings, for chrissakes.
Old 04-26-2005, 11:16 PM
markwemple's Avatar
markwemple
Everyone in for an engine drop?? Much easier
Old 04-26-2005, 11:24 PM
I just poseted this on another thread, so I'll put it here while the info is fresh - be careful when tightening done the nuts on the valve covers when done. Its not time to go Cro-Magnon on these things. Tighten them in a alternating pattern and to the proper specs to avoid warping the cover and getting leaks. I have the right spec torque wrench you can borrow if you need it.
FYI, I also have a new Carrera valve colver gasket set here at home if you want to do the adjust this weekend.
Old 04-26-2005, 11:29 PM
Parenn911's Avatar
Good call Chris ! We all know of Emery's "iron death grip", if he's able to snap off lug nuts with his bare hands, who knows what he'll do to the valve cover hardware .
quick question on valve adjustment cmcfaul@aol.com Porsche Technical Discussions 40 10-08-2008 09:03 PM
Newbie Question Regarding Bleeding Brakes TD in DC Porsche Technical Discussions 21 05-26-2005 07:54 AM
Valve stem failure! Mackpipes Porsche Technical Discussions 9 04-09-2005 09:33 PM
Changing valve springs cmartin Porsche Technical Discussions 15 11-11-2004 12:24 AM
The Beast developed a noise at VIR ... rs911t Porsche Technical Discussions 24 09-28-2004 02:26 PM
