Need help changing brake rotors - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Need help changing brake rotors
Old 03-17-2005, 01:38 PM
rs911t's Avatar
rs911t rs911t is offline
rs911t has one HoF thread
Default Need help changing brake rotors
Skippy needs front rotors. Unfortunately, it requires removal of the hubs. This is outside of my experience and I suspect beyond my tool collection. Anyone care to undertake such a project? Also, what else will I need? New bearings? ?
Thanks!
Greg DuPertuis
Leesburg, VA
Old 03-17-2005, 01:45 PM
APKhaos's Avatar
APKhaos APKhaos is offline
APKhaos
Greg,
Front hub removal = easy peasy, with no special tools required.
No need to replace the bearings unless they are shot, or unless you have a need to increase the scope of the rotor replacement project by a factor of 2 or 3.
Let me know when you have the front up in the air and the calipers off [just support them - don't disconnect the brake lines] & I'll come over.
Tony K
PCA Potomac, Rennlist Member
89 944 Turbo
85 Carrera - Sold
TrackVision
944Cup
Old 03-17-2005, 01:53 PM
Pretty sure Turbo hubs are similar to 911 NAs (except for the additional offset, 22mm?). You just need to take the caliper off and then the big nut under the dust cover on the spindle. There’s a cotter pin to remove, then the whole shooting match just pulls off. Do you have “floating rotors”? I thought they could be changed without removing the hub? If not there are I believe five 10mm (?) across-the-flats nuts and bolts that mount the rotor to the hub. Bearings are cheep, but why or why not replace should depend on condition. Look for obvious “sliding” (wear) or dark spots (heat).
Old 03-17-2005, 02:29 PM
APKhaos's Avatar
APKhaos
David,
The scope creep I mentioned was the process of removing the races adn presing in the new ones. Its just more work. Not difficult, but needs to be done with the right tools & a press to avoid damaging the inner hub faces.
Tony K
89 944 Turbo
85 Carrera - Sold
TrackVision
944Cup
Old 03-17-2005, 02:37 PM
No worries, I actually posted mine without reading yours so I was stating that which had been said before… again
Old 03-17-2005, 02:54 PM
jpinkert's Avatar
jpinkert jpinkert is offline
jpinkert
Two words of warning I have about 930 brakes - dust cover. I spent more time just removing the dust covers than I did on the rest of the rotor replacement process.
On non-930 brakes, the dust cover can be hammered, pried at, etc. On the 930, it presses into the spacer/hub assembly so you'll need a good slide hammer or something similar to extract it. I built a device to pull the dust cover out, but it self-destructed while pulling the second dust cover off.
- Josh
- '72 911T
- '81 SC
Old 03-17-2005, 03:42 PM
APKhaos's Avatar
APKhaos
Good tip Josh - thanks!
Now, where is that slide hammer........
Tony K
89 944 Turbo
85 Carrera - Sold
TrackVision
944Cup
Old 03-17-2005, 03:45 PM
87turbolook911's Avatar
87turbolook911
Ditto on what Josh said.
You'll have to thread a bolt into the dust cover fitting and use a slide hammer to remove. You'll be surprised as to how much effort is required to remove those damn things.
I've got one you can use..
Vu
Old 03-17-2005, 03:53 PM
Have you got a good source? Vertex runs them for $289 a piece.
Old 03-17-2005, 03:54 PM
APKhaos's Avatar
APKhaos
Jase,
Greg already has the rotors - an eBay/Pelican/Rennlist deal. Not sure which.
Tony K
89 944 Turbo
85 Carrera - Sold
TrackVision
944Cup
brake flush and replacing caliper dust boot ptsheridan Porsche Technical Discussions 5 05-03-2005 07:11 PM
Big red brake kit jpnovak Porsche & BMW Parts For Sale/Wanted 6 04-07-2005 10:25 AM
Brake bleed advice needed michael lang Porsche Technical Discussions 10 03-25-2005 05:03 AM
loose rear bulbs & third brake light wiring issue. fixes red911carrera Porsche Technical Discussions 6 10-27-2004 05:48 PM
Brake System Ken Robinson Porsche Technical Discussions 48 03-22-2004 04:27 PM
