interesting spring compressor - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » interesting spring compressor
Old 03-12-2005, 07:09 PM
markwemple's Avatar
markwemple
Default interesting spring compressor
So, I am finally puttling on the p/cs and while sliding the #2 set in (with the wrist pin and clips in place of course) the piston moves a little too fast and partially exposes the oil ring. So, as the compressor I am using is no the type that you can use w/pliers, I had to come up with an altenative.
Voila, the good old band clamp!! Works for one ring anyway. Anyone else run into this problem or am I the dork among "dorks".
Old 03-12-2005, 07:37 PM
Yes, used to use thin sheet metal and a couple of clamps to install piston and rods into iron cheby and furd blocks
T-Bar = Spring Rate Chart? BillJ Porsche Technical Discussions 1 06-06-2005 08:58 AM
in the market for a compressor? type954 Miscellaneous Discussions 3 03-29-2005 01:15 PM
Compressor? BlackTalon Miscellaneous Discussions 27 12-14-2004 11:22 PM
Interesting Newspaper Article About VIR Doug E Track Talk 3 07-24-2004 12:38 AM
Interesting BMW CCA req. Jase007 BMW Technical Discussions 3 02-26-2004 12:10 PM
