Hardened Rear Sway Mounts - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Hardened Rear Sway Mounts
Old 02-13-2005, 08:35 PM
William Miller's Avatar
William Miller
Default Hardened Rear Sway Mounts
New 22mm sways showed up Friday.
This weekends project was to strengthen the mounts:
Before: Mine were in great condition, no tears, or nuts breaking thru.
I added pieces of 1/16" steel plate on the bottom face and the outside:
I saw a simular diagional brace on Pelican BBS and thought it was a great Idea. This is actually a piece of steel chanel It's about 2-1/2" wide and has little wings on the ends that stiffen it. Most of it is about 1/8" thick.
I'm now waiting for the paint to dry so I can hang the new sway bar!
Thanks! WCM (Bill)
'81 911 SC Red Targa 3.6
'08 335i Blue Sedan
'05 Chevy Tahoe green
'98 Jeep Cherokee XJ "Blue"
'01 Toyota 4 Runner "Pearl"
Darnestown, Maryland
Old 02-13-2005, 09:21 PM
APKhaos's Avatar
APKhaos APKhaos is offline
APKhaos
Outstanding work, Bill. That looks a lot like the way mine were in the final phase ie. after teh stock, reinforced stock, and after-market specials had failed. With that triangulation, you are set to mount up the killer 30mm Smart Racing sway bar to go with your 31mm torsion bars and revalved shocks. Its a nice setup if that's what you have in mind.
Be sure to get some rust proofing up there before the shipworm starts munching.
Tony K
PCA Potomac, Rennlist Member
89 944 Turbo
85 Carrera - Sold
TrackVision
944Cup
Old 02-13-2005, 09:52 PM
jpnovak jpnovak is offline
jpnovak
Nice work!
Jamie
Old 02-13-2005, 10:30 PM
William Miller
Thanks,
Paint's dry. Going to get some undercoating tomarrow.
I just ran out to test fit the bar.
One side fine.
The other side I snapped off the end of the encentric bolt.
After I read the directions..... 45 ft lbs. I swear I didn't put that much on it.
The stock encentric nuts must have taken 150 ft. lbs to break loose.
Now I'm stuck!
I wonder how hard it is to find this odd ball part.
Wonder if I can drill thru the encentric part and install a hardened bolt thru the whole thing.
Think it will work?
Thanks! WCM (Bill)
'08 335i Blue Sedan
Old 02-14-2005, 09:42 AM
jpnovak
Which eccentric? toe or camber? I might have one left over from my build.
If its a ride height eccentric, can't help.
Jamie
Old 02-14-2005, 10:40 AM
William Miller
Sorry, should have been more specific.
On the instruction sheet it's item F. With their sway bar, you replace the stock Toe eccentric bolt with the one supplied in the kit. The drop link attaches to the center of the inside of this.
This is the good side:
The instructions state that for a starting point slide the clamp on the drop link so that the drop link will be verticle. Because of the bend in the bar, I can't get it any further foreward. The drop link is not verticle. The diagram nor the instructions tell you which way is up on the bar. I'm thinking maybe I have it upside down.
Thanks! WCM (Bill)
'08 335i Blue Sedan
Old 02-14-2005, 11:02 AM
William Miller
Here is a picture of the break.
Any metal experts out there?
This doesn't look like good steel to me.
The mating surfaces are rough where it broke.
It doesn't show signs of streatching or twisting which I expected.
Sort of look like a break in something that was cast. (like pot metal or cast iron pipe fitting that cracked off.)
Thanks! WCM (Bill)
'08 335i Blue Sedan
Old 02-14-2005, 12:44 PM
Noah's Avatar
Noah Noah is offline
Noah has one HoF thread
Bill,
Looks like cheap steel to me. Weltmeister does not have a reputation for quality, even though their stuff does look pretty in the box.
For a good guide to fastener breakage, there was a long thread on Pelican recently started by "Craig911" about an ERP bump steer bolt that had sheared on his track car (the bolt was improperly installed). There was lots of good discussion/pictures/etc about bolt breakage.
I have the 22/21mm factory '86 Carrera sways on my car (with reinforced rear mounts). I'm going to get the Tarret adjustable rear drop links so I can set them up with no preload, and sometime in the future when I'm rich I'll get the Smart Racing sway bars, which are the simply the best there is (and expensive too).
I'd get on the horn with Weltmeister and request a new eccentric bolt.
Old 02-14-2005, 02:41 PM
William Miller
I read that thread.
I never thought those kits looked all that safe. It seems like there should be a better way to do it.
I've called both Tweeks (mamotorworks) and Weltmeister (Performance Products.) Their looking into what replacement parts are avalible. The drop links came in a prepackaged blister pack. Other parts were in their own packaging. I wonder if thay have anything seperate?
I'll post an update when I find something out. We'll see how their customer service hats are working these days.
Thanks! WCM (Bill)
'08 335i Blue Sedan
Old 02-14-2005, 02:52 PM
BobNovas's Avatar
BobNovas BobNovas is offline
BobNovas
I wonder if you could (oh god not the f word) fabricate a bracket that would work?
I had the same weltmeister bar on my car, installed by Ray Plewacki. Ray didn't like that eccentric so much that he didn't use it. I forget how he mounted it but it wasn't with that part. He didn't like the angles. I've since gone back to the stock bar, and like Noah said, I'm waiting for the scratch to afford a Smart Racing bar or the unobtainium Charley bar. But anyway, why not give Ray a call and see how he mounted mine - he'd probably remember. (ASG - Phone: 703.876.2811)
Bullet prove sway bar mounts Trak Ratt Porsche Technical Discussions 0 05-13-2005 09:55 PM
Anatomy of rear wheel bearing? flatsixcrazy Porsche Technical Discussions 6 04-29-2005 07:32 AM
Weltmeister 22mm rear sway bar for 911 BobNovas Porsche & BMW Parts For Sale/Wanted 6 04-10-2005 08:09 PM
rear 22mm weltmiester adjustable sway bar. William Miller Porsche Technical Discussions 5 01-27-2005 04:10 PM
sway bars? Mackpipes Porsche Technical Discussions 9 09-25-2003 09:07 PM
