Any driveway for rent? - Dorkiphus.net
Navigation » Dorkiphus.net > Miscellaneous Discussions > Miscellaneous Discussions » Any driveway for rent?
Old 02-06-2005, 03:57 PM
flatsixcrazy's Avatar
Default Any driveway for rent?
Hi Everyone,
I am in need of a space to store any 1971 roller I just bought on ebay, from DC automotive, with the intention of dropping a 3.0SC engine and trans into it. I will be stripping my 78SC targa for parts that I can install onto the 1971T. I only have room to work on one car in my garage and I am looking to rent a space in your driveway for a few months until I get ridd of the SC body. You are more than welcome to claim the SC body and do what ever you need with it. Please let me know if you've got a space in your driveway and how much is the rental fee?. Thanks for all your help. Andy
Andy
11 Cayenne S White/Tan SUV
72 911T Black/Black Coupe
73 911E Bahia Red/Black
Old 02-06-2005, 04:02 PM
Here she is:
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
Andy
Old 02-06-2005, 08:00 PM
No driveway sapce here, but looking at the car you bought, looks like you're in for a hell of a project - but a fun one. No sunroof longhood with a big engine... should be nice. You going to go lightweight and put some firberglass fenders on it?
Old 02-06-2005, 09:36 PM
vove's Avatar
vove vove is offline
vove
Nice buy Andy. Man, you have too many projects at hand. I might know of someone with space that you can rent if you are interested.
Old 02-07-2005, 09:45 AM
BillJ's Avatar
BillJ BillJ is offline
BillJ
Wish i had space for you! Saw that chasis as well and already has a great color scheme. Whens the drop?
Old 02-07-2005, 11:11 AM
type954's Avatar
type954 type954 is offline
type954
hmmmm, maybe.... tell us all about the condition/shape of the SC. what parts to you know you are removing from the SC?
Old 02-07-2005, 11:16 AM
Hey guys,
Chris
Yeah, I have always wanted an early coupe so this is exactly what I was looking for. I'll probably will be doing the FG/carbon hoods and bumpers. I just bought a set of steel fenders for it from Karosserie.
T.
I am going to keep this roller and part out my SC targa. I am going to transfer as much interior and mechanical components as possible from the SC over to this roller and sell then what's left on the targa. I know that the sc brake calibers will be good on the 911T and I am still researching about the gauges and dash.
1973914
The drops will be sometimes this summer. I'll keep the list posted. I am still green about how to go about putting a 3.0 into an early car. My guess is that it is not that difficult. I hope I can put the 915 trans into the 71 chassis without major problems.
andy
Andy
Old 02-07-2005, 11:46 AM
Unless the ’71 came with “S” calipers you will need to install the struts too. So you should probably install everything except the A arms from the SC. The early A arms have the correct through the body sway bar mount. Not that you can’t add them to the SCs but why bother? All you need for the 915 and 3 Ltr. is a big hammer, 1 or 2 hits on the driver side tunnel by the rear seat tubs and of course the shifter and clutch cable. Note: it might fit without modification but will probably sound just like a rear wheel bearing going bad as the trans works against the tunnel without the extra clearance. The alloy control arms and adjustable spring plates are a nice upgrade in back too. Gages all fit but you will need to run a wire from the trans for the speedo. Seats require an adapter, easily made or get them from Performance or ??. You’ll need to install all the SC FI paraphernalia including the fuel pump unless you switch to carbs. Changing out the electrical panel to the left of the engine simplifies this a lot.
Old 02-07-2005, 12:00 PM
vove's Avatar
vove
T.
Good choice Andy. Cant wait to see the final product here, I know its a lot of work but well worth the time if your hearts in it.
Old 02-07-2005, 01:46 PM
Hi David,
Wow, thanks for the tips. Can I use the SC (shortshift) shifter assembly and shifting linkage or will I be using 71's shifter and it's linkage?, and can I use the same external oil cooler (trompone style) setup or will I need a new system riged up?.
T.
I am looking at around 12 months to transfer everything from the SC over, now that I am done with the clinical rotations and I am very green on transplating (Porsche engines, that is).
Andy
Andy
