Would you use a used oil cooler? - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Would you use a used oil cooler?
Old 01-28-2005, 05:34 PM
Dave O's Avatar
Dave O Dave O is offline
Dave O
Default Would you use a used oil cooler?
The oil cooler has been confirmed by Looper as having a leak that is not repairable (if I were even inclined to do so). Now I need a replacement. A new oil cooler is $900 in the best case (that I could find). What is the collective wisdom of the group about going with a used cooler (after it is checked out and cleaned)?
Slowly making progress on the maintenance tasks, did the valve adjustment this afternoon. Going to remove the fan and housing tomorrow so I can take all the bits in to be powdercoated. Having fun getting things cleaned up (and using the proane heater a lot).
Dave O'Bryan
1977 911 Carrera 3.0 Targa
1987 VW Westfalia w/ 2002 Subaru 2.5 engine at home , 1991 VW Vanagon Hightop camper in Europe, 1987 VW Vanagon Hightop Syncro camper out West, 2014 VW Jetta TDI Sportwagen
Oil Cooler Cliff Claven Porsche Technical Discussions 33 06-05-2005 08:39 PM
Aux Oil Cooler Needed? swftiii Porsche Technical Discussions 9 11-03-2004 04:30 PM
Cooling fan for oil cooler cmartin Porsche Technical Discussions 17 05-27-2004 10:24 AM
Oil Cooler Fittings? Charlie Stylianos Porsche Technical Discussions 5 04-02-2004 08:48 PM
Front Oil Cooler Questions Arlington77Targa Porsche Technical Discussions 6 04-01-2003 10:29 PM
