Head Stud Removal Tool - Dorkiphus.net
Navigation » Dorkiphus.net > Classifieds > Tools Needed/For Loan » Head Stud Removal Tool
Tools Needed/For Loan If you need to borrow some tools, or have tools to loan, post here.
Old 01-10-2005, 05:00 PM
Charlie Stylianos's Avatar
Default Head Stud Removal Tool
Will only need for a week. Will pickup and return promptly.
-TIA
Kyriakos E. Stylianos
Baglama inspired
Old 01-14-2005, 03:49 PM
William Miller's Avatar
William Miller
Charlie, I figured someone would respond. I have one, maybe 2 types. The one I'm sure of has a hole that the stud goes thru and the ratchet attaches to a cam in the center of the tool. When you turn the ratchet it grips the stud and turns it at the same time. Kinda like a monkey wrench but closed ended.
I bought it for my rebuild, but I don't think I had to use it.
I wonder what your working on?
I'll be arround this weekend. Hope to make it to the drop on Sunday and off Monday. Sill have my numbers?
Thanks! WCM (Bill)
'81 911 SC Red Targa 3.6
'08 335i Blue Sedan
'05 Chevy Tahoe green
'98 Jeep Cherokee XJ "Blue"
'01 Toyota 4 Runner "Pearl"
Darnestown, Maryland
Old 01-14-2005, 03:51 PM
William Miller
Forgot, I have a real torch if you want to use it. It might be easier to move the case if it's disassembled. I'll need the torch here as I hope to figure out what to do with my roll bar. Are you just replacing 1 stud or a bunch?
Thanks! WCM (Bill)
'08 335i Blue Sedan
Old 01-14-2005, 04:43 PM
Thanks Bill.
I was able to source one last night, not that I really needed it after all. I could have put a set of vise grips on those studs and removed them.
Baglama inspired
Old 01-14-2005, 09:21 PM
Doug E's Avatar
Doug E Doug E is offline
Doug E
Thanks for not telling me before how easily they came out.
I still have dreams about a few of the battle's we had with mine last year
1981 911 SC
Old 01-15-2005, 10:33 AM
William Miller
Charlie, that's what happened on my motor. I expected the worst so I bought the tool. Not needed. The studs had already been replaced with the fully threaded type. They were easily turned with double nuts.
One of the issues was that whoever installed them didn't have them all at the same height. Or, over time some worked loose. One was actually in so deep that one barrel nut had almost no threads to grab. It worked itself out. I did use locktight when re-installing them and got them at the right measurement. So I wonder why some are unbelievably tight and other's arn't. Mine are explainable because it probably wasn't loon since the last time it was opened up.
Anyway how's the project going!
Thanks! WCM (Bill)
'08 335i Blue Sedan
Old 01-15-2005, 02:41 PM
The project is coming along nicely. Should have the top-end, cams, SSI's, p-coat, and misc. parts, gaskets, etc all within the next few days, then rebuilding can resume. For now, just going through the CIS and cleaning bits.
BTW: Using OEM steel studs securing w/ blue loctite.
Baglama inspired
Exhaust stud removal help dyerkes Porsche Technical Discussions 11 11-06-2007 09:43 AM
Wheel stud removal BobNovas Porsche Technical Discussions 4 03-29-2005 02:00 PM
Broken Head stud!!! tdatk Porsche Technical Discussions 14 11-29-2004 11:44 AM
Tensioner Tool Manifold spreader tool. oneblueyedog Porsche Technical Discussions 2 01-29-2004 12:02 AM
PLease help with Alpine head unit removal Andrew Luu Porsche Technical Discussions 4 05-07-2003 03:15 PM
