I bought this big HF torque wrench a few months ago because I needed something to torque my lug nuts. I torqued them 5ft-lbs too low and when Jim and David R took off my back wheels they said there wasn't a lot of torque on them.
On a 90-95ft-lb bolt, would you really notice that much? Maybe they we're really under torqued... My big concern is that I'm doing a clutch job and certainly don't want to foul up all the expensive (not that wheels aren't) internal parts by getting an incorrect setting. My other two t-wrenchs are Craftsman, so I feel a better about them, but am on the fence on this big one. Eric D told me once that someone tested the HF t-wrenchs and found them to be in spec. Thoughts?
Steve, go to Sears and buy a Craftsman torque wrench. Although I like HF for most of their tools, I wouldn't trust the quality of their torque wrenches.
Kurt showed me how to test a torque wrench - use two torque wrenches and enough adapters and sockets to hook one to the other. Then torque away and see what happens wrt clicking or dial indicators or whatever - one known good wrench can telltale another unknown quality wrench. This is assuming, of course, you have a good wrench.
[quote="david riley"]
Don't listen to Kurt! Using one to test the other is a crude way to see if one is WAY off but that is about it.
Actualy this is Kurt using Bills account. For real! |
FWIW I used the HF 3/8" and 1/2" Torque wrenches last winter when rebuilding my engine and so far everything is still working
1981 911 SC |
