1980 911 SC Euro
My 17 year-old son comes home last night and says Dad > no instrument lights in the 911. [see what a good dad I am > my boy gets more 911 stick-time than I do] I look to find the fuse that handles the instrument lights and > no joy > can't seem to find out which fuse handles instrument lights.. Interior dome light - ok fan-ok headlights -ok ??
Kim Langley 1980 911SC [Euro spec] 1997 Mercedes C230 1973 BMW 2002Tii 1999 BMW M3 [son- Nick] 2008 Kawasaki Ninja 650 [son-Ryan] |
Your fuse may be ok. It may just be the normal level of illumination. :P
I'm not 100% on this, but I don't think there is a fuse for the dash lights. I say this because I seem to recall a lot of threads on Pelican about retrofitting one.
The source for the dash light circuit is going to be the headlight switch. Start your troubleshooting there.
Chris is correct - no fuse.
If all instrument lights are mysteriously out, check the dimmer. Its possible that the dimmer was knocked to the full dim position.
thanks;
yeah >> right after I posted this.. I noted to myself that I had not checked the position of the dimmer... will check tonight..
Dash board lights are “in concert” with the tail lights (not brake). Someone way back in time thought that it would alert people to their brake lights being out. Of course they don’t actually tell you that! Check the tail light bulbs & the fuse if the other stuff doesn’t pan out.
Dash lights are not fuzed. They come on at the first detent of the headlight switch. Power comes from terminal 30, goes through detent switch, through dimmer rheostat and exits switch through terminal 58a. From here it goes to all dash lights. Twist rheostat (dash light dimmer) to check function.
If no function, lift off all black/blue and black/red wires from terminal 58a and check terminal with test light by turning knob. If no function with test light, problem likely in headlight switch. If you have function, then one of the dash lights or wires is drawing too much current. Track down problem from this point. |
As an aside, does anyone find the lighting for the speedo to be particularly dim when compared to the other gauges? It is barely lit up on my '87 and yes, I checked the bulb.
- Josh - '72 911T - '81 SC |
I checked the headlight/dimmer switch and it was turned full left >> ergo no instrument lights >> turn right >> whollah >> we have instrument lights
Note to self >> check hte easy things first I feel like a rookie...
Keep in mind these lights do dim over time, so even if they work they might not be very bright. Try replacing them with new ones and I bet you'll notice a difference.
| Help - brake lights stopped working, need to drive it | winstonbike | Porsche Technical Discussions | 11 | 06-01-2005 11:12 AM |
| Pulsing Head Lights | sccaracer | Porsche Technical Discussions | 5 | 03-14-2005 03:07 PM |
| Rally Lights? | Trak Ratt | Miscellaneous Discussions | 9 | 04-08-2004 07:28 PM |
| Fog lights fuse location | estrellajon | Porsche Technical Discussions | 15 | 01-21-2004 12:28 AM |
| 911 Comes Through, until I leave the lights on | Gordo | Miscellaneous Discussions | 1 | 01-25-2003 06:43 AM |
