![]() From this picture it is apparent that the clutch and gas pedal are much closer to the floor board than the brake pedal .
For the street you can attach a block of wood :P
I had such a good idea, that apparently Don had it too in the Track forum:
You can adjust the gas pedal by pulling it off the ball and turning the rod in the disired direction.
Brake pedal is more difficult and you have to make sure when you shorten the rod length that you are not placing and pressure on the master cylinder. May not be obvious, but even a slight amout of pressure on the MC will keep the pads engaged on the rotors.
Thanks for the replies Marc and Steve
Any input on how to adjust the clutch pedal? Could it be that my clutch itself needs adjustment? |
Pari, come by and look at mine while it's up on the stands.
Barrow my book and do the adjustment. It looks like it's possible that it's out of adjustment, the helper spring is hung up or one of the springs near the pedal cluster is missing or weak. I found that my helper spring was hitting the seam on the SSI heat exchanger and it wouldn't allow the helper spring/arm to return all the way. This would of course throw the adjustment off. When you push on my pedal there is very light resistance for about an inch. This effect is because of the 1mm gap (Supposed to be there and part of the adjustment) between the little arm that turns the shaft and th big arm that the cable pulls. I think the gap on yours may be too big and there is a problem with one of the springs. I'm glad you posted. One of the questions I'm sure everyone wanted to ask, but didn't. I think I'll look at my gas pedal as well. Unfortunately the bottom hinge point does not adjust very far if any. I think that's where the wood block may come in handy. I have some aluminum stock I got from a freind who's in the scrap metal business. It's about 1/4" thick and has a texture on one side. It's about the size of a stair tread so that's where I think it came from. If anyone want's a hunk let me know, make yourself a pedal with a wing!
Pari, Order yourself one of the Wings accelerator pedals. It not only has an extended piece for heel and toeing, it goes on top of the accel. pedal and can be adjusted up, down and sideways. I had the same problem as you heel and toeing until I installed one, and it made things a lot easier. You can take a look at mine and give it a try if you like.
The guy who makes it advertises, or did, in Pano and Excellence. Bill |
You can also take those big rubber things off the clutch and brake pedals, and just go with the metal pedal. That will put the brake closer to the gas.
Pari, and others... keep in mind that even with just a small amount of water on the bottom of your shoes, the metal pedals will be extremely slippery. If your shoes are damp, make sure you contact the whole pedal. Just using the edge of the pedal will probably result in your foot slipping off.
As far as pedal kits that help heel-toe... the one several of us use is from rennline. It looks like this... ![]() And can be purchased at rennline's web site. Rennline now also has a fully adjustable kit for about 2X in $$$. Looks nice but probably not worth it for the non-racer.
| Bilstein shock adjusting tool | Terry #44 | Porsche Technical Discussions | 7 | 06-01-2005 03:54 PM |
| Adjusting headlight the upfixin way? | OldTee | Porsche Technical Discussions | 12 | 05-04-2005 03:58 PM |
| Adjusting shift coupler | Parenn911 | Porsche Technical Discussions | 17 | 04-17-2004 01:53 AM |
| Valve Adjusting Method--Threat or Menace? | targa911man | Porsche Technical Discussions | 9 | 09-16-2003 01:39 PM |
| Hey guys, Adjusting the valves (no video) can anyone help? | mada | Porsche Technical Discussions | 0 | 03-13-2003 09:14 PM |
