97 M3/4/5 109k miles original owner - Dorkiphus.net
Navigation » Dorkiphus.net > Classifieds > Porsche & BMW Cars For Sale/Wanted » 97 M3/4/5 109k miles original owner
Porsche & BMW Cars For Sale/Wanted Post For Sale or WTB adds for Porsche & BMW cars here. Strictly moderated.
Old 06-09-2025, 10:29 AM
mlytle mlytle is offline
mlytle
Default 97 M3/4/5 109k miles original owner
1997 BMW M3/4/5
Techno Violet over Mulberry
Lux Package
109k miles
One owner Florida/Virginia car
09/96 order date, 12/96 build date, 01/97 delivery date.
All original panels and paint
No accidents, no paint work, no rust, no stories, no issues
All maint, work and mods since new done by mechanic owner
M-Contour Type 23 wheels 17x8.5 all around.
245/40 17 Michelin Pilot Sport tires
Alpine UTE-73BT head unit
Spilt fold down rear seat back
Cold A/C
Sunroof inner liner redone in black Ultrasuede
Door handle and rear window gaskets replaced
BMW car cover
Colgan nose and hood bra
Everything works as new
Known issues
Rock chips on nose commensurate with mileage
A-pillar covers just starting to have fabric peel on top edge
Headliner replaced with new BMW part 12 years ago, but starting to sag again in back
Aftermarket fog lamps. PS lamp has rock chip.
The Color Techno Violet Metallic
The beauty of Techno Violet is that it is a chameleon. It takes on different hues based on the light it is in. Indoors or bright sun, it is a deep shade of purple. In twilight?a bluish purple. As it gets dark, it looks more black. The attached pictures were taken in in a variety of lighting conditions from twilight to sun to indoor
https://photobucket.com/share/81a4a6...6-5e3e64b3eaaa
Everything below was done in last 10k miles unless otherwise noted
Suspension front
Control arms
Tie rods
Powerflex Purple offset CAB?s
Ground Control Struts w/ 2.25in dia springs
Koni SA Dampers
Ground Control Hybrid Camber Plates
UUC sway bar
X-Brace
Aluminum bumper undertray
Suspension rear
Koni SA dampers
PowerFlex Purple subframe bushings
RTAB pockets reinforced
UUC sway bar
Sway bar mount points reinforced
Ground Control adjustable spring perches w/2.25in dia springs
Stock upper and lower, inner and outer CA bushings
Stock Diff bushings (90k miles)
Engine/Transmission
Stock internals
No leaks!
Shark injector tune
PWR aluminum radiator (80k miles)
Aluminum TStat housing(80k miles)
Stock engine mounts (90k miles)
Stock trans mounts(90k Miles)
Rogue Engineering short shift system(70k miles)
Shift detents fixed (70k miles)
Sachs sport clutch(70k miles)
Slave cylinder (70k miles)
CDV delete
BW Stainless clutch line(70k miles)
Mobil 1 or Redline engine oil every 3k miles
Redline D4ATF trans fluid
Redline 75w90 Diff fluid
Active Autowerkes GEN1 cat back exhaust (installed at 1k miles)
Brakes front and rear
Calipers rebuilt (90k miles)
BW SS brake lines (90kmiles)
PFC Z rated pads
ATE Type 200 fluid (yearly)
located in Alexandria, VA
Marshall
95 M3
97 M3
25 M2
Old 10-03-2025, 04:26 PM
mlytle
Car is now live on BAT.
https://bringatrailer.com/listing/1997-bmw-m3-320/
Marshall
95 M3
97 M3
25 M2
Old 10-10-2025, 07:48 AM
mlytle
Today is the last day of the BAT auction....
Marshall
95 M3
97 M3
25 M2
Old 10-11-2025, 09:37 AM
Wow congratulations
Old 10-12-2025, 07:58 AM
mlytle
It went well...
Marshall
95 M3
97 M3
25 M2
