Any Low Smoke 2-stroke oil suggestions - Dorkiphus.net
Navigation » Dorkiphus.net > Miscellaneous Discussions > Miscellaneous Discussions » Any Low Smoke 2-stroke oil suggestions
Old 06-07-2024, 05:05 PM
Default Any Low Smoke 2-stroke oil suggestions
I got another old 2-stroke Ducati and wondered if the brain trust here has suggestions on lower smoke oils to use.
Being an older bike it takes between 16:1 and 20:1 mix (i.e. lots of oil compared to modern 2-strokes). Actually the manual states it as 5-6%
Also, would a full synthetic allow for more lubrication so I can run a less oil in the mix?
Thanks for suggestions.
‘19 SQ5
Old 06-08-2024, 09:31 AM
Chopper Dropper's Avatar
Chopper Dropper
Castrol R for the perfume!! Only way to go.
Dirk
1988 911 Targa
1986 944
Old 06-29-2024, 09:21 AM
onboost's Avatar
onboost onboost is offline
onboost
I always like Klotz for the perfume.. great stuff.
RGruppe #180
PCA Potomac + 35yrs
Old 06-29-2024, 12:34 PM
trytryagain's Avatar
trytryagain
Pictures would be nice!
Jim C.
1971 914 (back in the day)
Old 07-03-2024, 11:47 AM
You can run less % with modern synthetic oils. Typ go w/ what is recommended on the oil and not in the old manual. Something like Redline you'd likely use 50:1 or less. Stihl makes a good low ash that burns fairly completely. Many of the high-perf air-cooled RC engine guys use it. I'm in the Redline camp (for both RC and the dirtbikes).
Be aware there are high and low flashpoint 2-stroke oils. The low flashpoint will burn fairly completely. Better for average trail riding, trials bikes, etc. If you are riding motocross w/ the throttle pinned most of the time, a high flashpoint oil is better but it won't burn off if you aren't riding like a maniac.
1984 930 - 3.6L
