ISO: 2.25" Coil Over Springs - Dorkiphus.net
Navigation » Dorkiphus.net > Classifieds > Porsche & BMW Parts For Sale/Wanted » ISO: 2.25" Coil Over Springs
Porsche & BMW Parts For Sale/Wanted Have Porsche/BMW clutter? Need something for your car? Post For Sale or WTB adds here. Strictly moderated.
Old 02-13-2024, 02:18 PM
ducatithunder's Avatar
ducatithunder
Default ISO: 2.25" Coil Over Springs
Looking for a pair of 2.25" coil over springs. Don't care about the lbs rating as its a temporary thing. 9" length should suffice. I am getting back into working on the rsr project and need to set the ride height for body work purposes. I picked up a set of coil overs years ago to allow it to be moved. The springs that came on them are 2.5" so not even close to being the correct size to work with the shock perches. Figured someone might have a local pair collecting dust in the corner before I order a set from Summit. Thanks.
Current
07 Mini Copper S
99 Dodge Viper ACR
65 Shelby 427 SC
07 Ducati 1098
17 Alfa Giulia Quadrifoglio
Projects
86 "Backdate" 911 2.8 RSR
73 911 T Targa (Sold)
Old 02-13-2024, 09:39 PM
jashford jashford is offline
jashford
I have a pair of springs but where do you measure for 2.25?
They are 9" but the ID is 2".
John
John
Old 02-13-2024, 10:09 PM
ducatithunder
John
This is the spring perch ID ... should be 2.25"ID for spring. The one I got when I bought this setup is sloppy 2.5"ID spring.
Current
07 Mini Copper S
99 Dodge Viper ACR
65 Shelby 427 SC
07 Ducati 1098
Projects
Old 02-13-2024, 10:31 PM
jashford
When I saw your post I was hoping you could use them. I hate to throw them away.
John
Old 02-13-2024, 10:59 PM
ducatithunder
I appreciate it man. I hate to buy springs to literally throw away in a years time.
Current
07 Mini Copper S
99 Dodge Viper ACR
65 Shelby 427 SC
07 Ducati 1098
Projects
Old 02-13-2024, 11:16 PM
This is a guess:
Looking at the thickness of the springs, and considering that the part that will touch the perch is NOT the innermost edge but the center of the metal coil, is it possible 2" ID might fit just fine? What's the diameter of the damper it needs to fit around?
Old 02-13-2024, 11:45 PM
ducatithunder
This is a guess:
It's not impossible. Would require a test fit. I would have to measure the OD of the shock but eyeballing it based on the 2.5" spring would work. There is a lip on the upper perch with a raised lip, maybe 1/8" that is 2.25" to center the spring.
Honestly, grinding it away the spring to make it work would not be the end of the word. It would just scrap the spring at the end of the day. My goal here is to make reliable suspension adjustments for bodywork fitment/adjustments.
Current
07 Mini Copper S
99 Dodge Viper ACR
65 Shelby 427 SC
07 Ducati 1098
Projects
Old 02-14-2024, 06:31 PM
ducatithunder
So the springs in questions were 2" and did not fit over the shock bodies. Thanks again John for meeting up with me today to test them.
Current
07 Mini Copper S
99 Dodge Viper ACR
65 Shelby 427 SC
07 Ducati 1098
Projects
Old 02-14-2024, 11:03 PM
If you just want to “set the ride height” why not just jack the car to the desired height and unloaded front suspension, then measure and cut some tube or pipe to size? Might even be able to use PVC?
Old 02-15-2024, 02:04 PM
TurboPooch's Avatar
Now known as Robbie's dad
TurboPooch
I was thinking something similar only using metal conduit or black pipe to make a "non-bouncy spring". It will be about .2" too big in diameter but you could build up the spring perch with an O ring or some tape to keep it from sliding around. Doing a little math with the known weight of the car and spring rate you can figure out the compression of the spring and how long to cut the pieces to get the desired ride height so your collars will be close.
89 944 Turbo Race car
98 993 C2S w/Aerokit II
70 Boss 302
86 Mustang SVO
24 F250 SD Godzilla
