OIL CHANGE IN 911 - Dorkiphus.net
Old 05-19-2004, 12:58 PM
cmbenz cmbenz is offline
cmbenz
Default OIL CHANGE IN 911
Please pardon my ignorance, but is there a 'tried and true' method for changing the oil in my 911SC so I don't overill/starve my 3.0? I've been told that the true level of the oil is determined on the dip stick and to not rely on my gauge.. Also what brand is best? It currently has Castrol 20-50...should I change or continue to use it? I'm a novice Porsche owner, but been a big fan of these cars for many years. Can anyone help me or direct me to where I can get this info?
Thanks!
Charlie
78 911SC
Let's Tee It UP!
Old 05-19-2004, 01:21 PM
Default Re: OIL CHANGE IN 911
Thanks!
When I did it. I dumped the old oil (more on that later*) and filled up with 8-9 quarts. Then I started it up to circulate for a second and added one more. Then I let it idle for like 15 min to warm up and circulate through the car and checked the stick and added one last quart. I used Shell (see stickers in engine compartment) oil - 20W50 but I know some guys like Kendall, but IIRC, it's harder to find. Also, make sure you get the crush washers. I went to the dealer to get a filter and washers. I was at Arlington Porsche. If they try and charge you the full freight, make a fuss, Porsche corporate just jacked up the prices a whole lot and the manager there corrected them for me
*When I say I dumped it, I'm not kidding. The tank holds a lot of hot oil and it comes out REALLY REALLY fast. If you have one of those pans from Auto Zone with the tiny hole, cut it open now and save yourself the trouble of cleaning off the driveway or garage.
For more funny stories, do a search on Pelican, lots of good stuff.
Lastly, welcome to the board. Where are you located? Hope you can make it out to an event or an engine drop. Who knows, it could be yours.
Old 05-19-2004, 01:59 PM
cmbenz
VaSteve,
Thanks for the info! I would have surely dumped hot oil all over my garage as I do have a donut hole oil pan!
What do you mean by "crush washers"? How many will I need?
Charlie
78 911SC
Let's Tee It UP!
Old 05-19-2004, 02:16 PM
VaSteve,
Two. One for the tank and one for the sump.
Old 05-19-2004, 02:23 PM
cmbenz
Thank you! I live in Manassas Park and would like to come out for a fun run and/or engine drop!
Charlie
78 911SC
Let's Tee It UP!
Old 05-19-2004, 02:31 PM
Parenn911's Avatar
Loose Lips Sink Ships
Parenn911 has one HoF thread
This is what you need for an oil change, I recommend using a Mahle oil filter:
Crush Rings:
One of the crush rings is for the drain plug on the sump plate:
and the other crush ring is for the drain plug on the oil tank:
You need to drain the oil from both places when changing the oil. If the drain plugs are on too tight, you may have to tap the wrench with a small hammer to break them loose.
I highly recommend buying the Bentley manual for the SC's and/or 101 Projects for Your 911, both are good resources.
Old 05-19-2004, 02:35 PM
cmbenz
This is excellent! Thank you! I ordered those two books from Pelican Parts...
I appreciate your help!
Charlie
78 911SC
Let's Tee It UP!
Old 05-19-2004, 02:41 PM
Cool. I'm moving to Bristow in a few weeks. I'm building my BFE support network now.
Pari, please tell me you just took those photos....Why Oh, why would you have that on your computer.
Old 05-19-2004, 02:43 PM
cmbenz
Okay, I'll bite..."BFE"?
Charlie
78 911SC
Let's Tee It UP!
Old 05-19-2004, 02:59 PM
I thought everyone knew that one.
http://www.acronymfinder.com/af-quer...exact&p=ol
:P
What are the going rates for an oil/filter change? Noah Porsche Technical Discussions 43 03-18-2005 03:02 PM
Change of Plans - Home PPI frogers911 Porsche Technical Discussions 23 01-10-2005 01:33 PM
996 Oil Change ecohen Porsche Technical Discussions 7 12-27-2004 10:03 PM
First spark plug change this evening, do I have it right? 4to8m8 Porsche Technical Discussions 7 12-17-2004 08:17 PM
WHEEL CHANGE cmbenz Miscellaneous Discussions 13 06-09-2004 05:08 PM
